The problem with editing order
- Keks-Store
11 years 1 month ago - 11 years 1 month ago #216973
by Keks-Store
The problem with editing order was created by Keks-Store
-- Joomla version -- : 3.4.4
-- PHP version -- : 5.6.13
-- Browser(s) name and version -- : Any
When click on the "Edit" button in the backend in any order (for example, in the "address") disappears itself the "Edit" button and "save".
I can not save the changes, or fill in the Shipping and payer.
I ask for advice and help.
Last edit: 11 years 1 month ago by Keks-Store.
11 years 1 month ago #216996
by Xavier
Replied by Xavier on topic The problem with editing order
This can be a template issue, which template are you using in backend, the Joomla default one ?
Else this can too be a javascript error, if you use your browser console (F12) in the console tab do you have any javascript errors returned ?
- Keks-Store
11 years 1 month ago #217172
by Keks-Store
Replied by Keks-Store on topic The problem with editing order
I use Joomla default template ISIS. In Control Panel hikashop also set the default template.
I also tried to see javascript errors, but did not find them, or do not quite understand how to look for them.
Before hikashop 2.6.0 update everything worked properly. In addition to the smartphone buttons function, albeit with some problems.
This can be a problem on the side of the web hosting provider?
11 years 1 month ago #217200
Replied by nicolas on topic The problem with editing order
If the popups are not working, it's probably coming from the update of Joomla, not HikaShop :
www.hikashop.com/forum/install-update/87...to-3-4-4.html#214269
- Keks-Store
11 years 1 month ago #217220
by Keks-Store
You understood me wrong. In the attached image I just showed that I set the default template. Popups are working. Buttons do not work to change and save when i edit an order. When i press the change (picture step 1) Save button does not appear and the button to cancel the fall to the bottom (picture step 2), while it is not active.
11 years 1 month ago #217262
That's really strange as we don't have that problem on our end.
Could you provide a backend access to your website so that we could check the problem out ?
Please do that through our contact form with a link to this thread:
- Keks-Store
11 years 1 month ago #217297
by Keks-Store
Hi, submitted.
- Keks-Store
11 years 1 month ago #217477
by Keks-Store
Hello, did not wait for an answer, turned to deal with my problem?
- Keks-Store
11 years 1 month ago #217534
by Keks-Store
Problem solved, I cleaned the cache in the browser.
11 years 1 month ago #217543
Sorry for the delay. It's great that you found out.
So the popup fix we provided before did fix the problem but it was just that you hadn't cleared the cache of your browser. Good to know.
