- Thank you received: 2
Ordering problem
-- Joomla version -- : 3.5.1
-- PHP version -- : 5.6.20
-- Browser(s) name and version -- : firefox, chrome, any
We seem to have developed some severe ordering problems. I do not know if this is the cause, but we recently updated joomla to 3.5.1 and hikashop to 2.6.2
Issue 1 = when someone checks out and submits their order, they get this message:
Also the order emails do not go through to the customer or the store - but the order is in the hikashop backkend ok.
Issue 2 = When something is added to the cart, a different product gets added. If something at the top of this list is selected, only the item at the bottom of the list gets added. (with a very different price) If you go to any page ( www.beeswaxcandleshop.com/Honey-Soap-Mor...ml?jsn_setmobile=yes ) and add an item at the top of the selection list you will see the action.
Issue 3 = The left side bar is not showing on hikashop products. (such as www.beeswaxcandleshop.com/Honey-Soap-Mor...ml?jsn_setmobile=yes ) Although if you scroll to the very bottom it shows up mostly off the screen on the far left side.
Any help you can give me to get my site back up would be welcome.
Bill
1. It looks similar to this one:
www.hikashop.com/forum/checkout/883603-4...-process.html#235445
However, it shouldn't happen as the 2.6.2 already includes the fix that it mentioned there.
So that means that you have somewhere an invalid email address configured.
It could be in the emails section of the HikaShop configuration, or in the settings of the emails when you edit them via the menu System>Emails.
Before the 3.5.1, Joomla didn't check the email addresses that much and now it's a bit too aggressive.
2. and 3. The problems come from the customizations of the product page layout in your template. Rename the folder templates/YOUR_TEMPLATE/html/com_hikashop/product via FTP and that will fix the problem.
Instead of renaming the whole folder, you can rename file by file and check which one is creating the problem.
html version"<?php
* @version 2.6.0"
and
text version "<?php
* @version 2.6.0
* @author hikashop.com"
Could this be a problem?
On the 2 & 3 issue, I found the folder (product) -- but which file do I rename and what do I rename them to?
1. No, you should look at the "Sender information" tab of the emails when you edit them.
2. I don't know which one is causing the problem. So try to rename one and see if that helps, if not, rename it back and try with the next one, etc until you find the one with the issue.
One the first issue with the checkout error - I thought that maybe it was because I was using an "alias" email - so I changed emails to one that is listed in my cpanel and not an alias. (although the address was not the same domain as the site)
I changed them all in:
- system global config
-hika-config-main-email section
-hika-system-email section - I changed them all to same in "sender information" section - note - all these now show that they have been "customized"
Another issue maybe related that I have been having is that after submitting an order and getting the error page - I click on the area that says "Go to the Home Page" and the main page comes up showing like the image below.
I have recently noticed that the address of this page is an https:// adresss and when I remove the "s" the page shows normal.
This is an issue I have had for a few months - It happens only occasionally but I have not been able to find the problem yet. This issue was occuring when the site was joom3.4.8 but the orders were going through ok.
2. These files are there usually because the template changes the layout of the product page. If you don't see a problem without them, you can leave them renamed.
1. What do you have at the bottom of that page when you have the "error reporting" setitng of the Joomla configuration activated ?
It should normally display an error message, providing more information on the issue.
Below is an image of what I have now.
It shows lots of customizations - but they just appeared when I changed an email address - the only real customizations are in the Order administrator notification
Right now I am getting a good notification to the store, but the customer receives nothing.
Make sure that entered a valid email address in the "From email" setting of your Joomla configuration. If that field is not valid, Joomla can crash each time HikaShop sends an email.
Then edit the order creation notification email and check that the sender information is correct in there.
If the problem is not with the email data, then it might be with the emails customizations.
What if you rename the folder media/com_hikashop/mail/ to something else via FTP and install HikaShop again ?
That will allow HikaShop to use the standard email files automatically. And if it works, it means that the problem comes from the customizations done in the emails. In that case, you can redo your modifications to the new versions of the emails.
If that still doesn't help, I guess the best would be to look in the error log of the server. Normally, when you get such blank page, there is a fatal error logged and this gives information on where the problem is coming from. Once we know that, we can tell you what to do.
2016-04-27T12:39:09+00:00 INFO 62.210.203.159 joomlafailure Username and password do not match or you do not have an account yet.
2016-04-27T12:39:12+00:00 INFO 62.210.203.159 joomlafailure Username and password do not match or you do not have an account yet.
2016-04-27T12:39:14+00:00 INFO 62.210.203.159 joomlafailure Username and password do not match or you do not have an account yet.
2016-04-27T12:39:17+00:00 INFO 62.210.203.159 joomlafailure Username and password do not match or you do not have an account yet.
2016-04-27T12:39:19+00:00 INFO 62.210.203.159 joomlafailure Username and password do not match or you do not have an account yet.
2016-04-27T12:39:22+00:00 INFO 62.210.203.159 joomlafailure Username and password do not match or you do not have an account yet.
2016-04-27T12:39:24+00:00 INFO 62.210.203.159 joomlafailure Username and password do not match or you do not have an account yet.
2016-04-27T12:39:27+00:00 INFO 62.210.203.159 joomlafailure Username and password do not match or you do not have an account yet.
2016-04-27T12:39:29+00:00 INFO 62.210.203.159 joomlafailure Username and password do not match or you do not have an account yet.
2016-04-27T12:39:31+00:00 INFO 62.210.203.159 joomlafailure Username and password do not match or you do not have an account yet.
2016-04-27T14:16:56+00:00 INFO 117.177.250.151 joomlafailure Username and password do not match or you do not have an account yet.
2016-04-27T18:19:38+00:00 INFO 117.177.250.151 joomlafailure Username and password do not match or you do not have an account yet.
2016-04-29T04:15:12+00:00 INFO 89.234.157.254 joomlafailure Username and password do not match or you do not have an account yet.
2016-04-29T10:41:45+00:00 INFO 176.126.252.12 joomlafailure Username and password do not match or you do not have an account yet.
2016-05-01T12:30:20+00:00 INFO 173.199.65.27 joomlafailure Username and password do not match or you do not have an account yet.
2016-05-02T12:53:34+00:00 INFO 134.249.141.24 joomlafailure Username and password do not match or you do not have an account yet.
2016-05-02T14:21:30+00:00 INFO 134.249.141.24 joomlafailure Username and password do not match or you do not have an account yet.
Or is this server log file something on my cpanel
I do see a lot of "duplicate database queiris" if that could be a problem.
I enabled every email except the "Order creation notification" and a test order went through ok. The "Order creation notification" is the only one causing a problem.
I also found that some of my Hikashop links no longer work:
This one:
beeswaxcandleshop.com/index.php?option=c...t=listing&Itemid=289
is shown in browser as: beeswaxcandleshop.com/Order-Beeswax-Candles/category.html (SEF SH404 settings)
And does not work.
This bad link is in the "order completed page" that may be in the hikashop system ("You can go back to the Candleshop by clicking on this link")
Could this be part of the problem?
Either way what would be the correct link to my catalog page.
I just did another test order with the "Order creation notification" enabled and it failed. With this turned off the system works.
Is there any way to make an email go to the customer? Some kind of WorkAround? This is the main problem.
