Problem with .pdf invoices
10 years 1 month ago #252068
by rober1903
Problem with .pdf invoices was created by rober1903
10 years 1 month ago #252069
by Jerome
Replied by Jerome on topic Problem with .pdf invoices
You should use the namekey of the order status which is
"Confirmado" is just the translation of the order status in your language but is not the identifier used by the HikaShop core.
confirmed
10 years 1 month ago #252126
by rober1903
Replied by rober1903 on topic Problem with .pdf invoices
10 years 1 month ago #252127
Replied by nicolas on topic Problem with .pdf invoices
It's in the setting "statuses for email attachment" that you need to enter "confirmed".
You don't need to change the setting in the HikaShop configuration.
10 years 1 month ago #252237
by rober1903
10 years 1 month ago #252239
You need to write "confirmed" in it, not "Confirmed". That's why it still doesn't work. Please do that.
Other than that, make sure that the plugin is enabled and its access set to "public".
10 years 1 month ago #252283
by rober1903
Perfect Nicolas!!!
Thanks so much!!!!!
Thanks so much!!!!!
