invoice numbers on pdf invoice do not match with order
- herb200mph
9 years 6 months ago #268684
by herb200mph
invoice numbers on pdf invoice do not match with order was created by herb200mph
shop.justducks.co.uk
-- HikaShop version -- : 3.0.0 BUSINESS
-- Joomla version -- : 3.6.5
-- PHP version -- : 5.6.3
-- Browser(s) name and version -- : All
Installed "AttachInvoice" PDF Plugin and it generates the attachment to the email properly.
However, the ORDER NUMBER in the confirmation email is: JD17-M2F58
The INVOICE NUMBER on the attached PDF is: JD-17-G1K47
The ORDER NUMBER does not appear anywhere on the PDF document.
Please advise resolution to present the same INVOICE NUMBER on the PDF as the ORDER NUMBER on the email/system admin.
Thank you.
Thank you.
- herb200mph
9 years 6 months ago #268685
by herb200mph
Replied by herb200mph on topic invoice numbers on pdf invoice do not match with order
Amending Question:
How can we print the System ORDER NUMBER on the PDF to show both ORDER and INVOICE numbers.
Rather confusing to both the customer and admin for referencing numbers.
We would like to display BOTH the ORDER NUMBER and INVOICE NUMBER on the PDF document.
9 years 6 months ago #268687
Replied by nicolas on topic invoice numbers on pdf invoice do not match with order
You need to edit the file plugins/hikashop/attachinvoice/attachinvoice/invoice.php and add your custom code below the line:
<div class="invoicetitle"><?php echo $number.$order->order_invoice_number; ?></div>
For example:
<div class="invoicetitle">Order number: <?php echo $order->order_number; ?></div>
For example:
- herb200mph
9 years 6 months ago #268740
by herb200mph
Thank you. We have performed the modification and will test the results.
Regards.
Regards.
