Problem with delete button in dropdown cart
9 years 6 months ago #269674
by Wrosch
Problem with delete button in dropdown cart was created by Wrosch
-- Joomla version -- : 3.7
-- PHP version -- : 7.0.18
-- Browser(s) name and version -- : firefox 53
Hi.
When I use the delete button for dropdown cart the first time the product is removed immediately from a cart and cart is empty, but the second time when I add product to the cart and try detete it, cart does not reload.
Hi.
9 years 6 months ago - 9 years 6 months ago #269679
by Philip
Replied by Philip on topic Problem with delete button in dropdown cart
From your description that will be hard to understand what's really going on.
Can you in order to better understand an Url link to process some tests (and references if needed to reached the checkout).
From your side, you can too try to process this test, try to recreate the issue but with a default template like ProtoStar.
Note : If needed you can use important references thanks to our Contact us form, and add an Url link to this topic.
Awaiting news from you.
Last edit: 9 years 6 months ago by Philip.
The following user(s) said Thank You: Wrosch
9 years 6 months ago #269737
by Wrosch
Replied by Wrosch on topic Problem with delete button in dropdown cart
Hi.
I followed your advice to test this "bug" with default settings and its work fine.
9 years 6 months ago #269758
Replied by nicolas on topic Problem with delete button in dropdown cart
I would recommend :
- Turning off the "add to cart legacy" setting of the HikaShop configuration.
- Deleting the override you have on the file "cart" of the view "product". You can rename the file templates/YOUR_TEMPLATE/html/com_hikashop/product/cart.php for that.
That way, you'll use the new add to cart and cart systems of HikaShop and it should work much better. Note however, that this might require some reconfiguration of the cart module and some CSS styling to be added to get exactly the look you had before.
I would recommend :
9 years 6 months ago #269979
by Wrosch
Thanks for explanation.
