Problem direct checkout after selecting a product
9 years 4 months ago #274207
by cpntnat
Problem direct checkout after selecting a product was created by cpntnat
-- Joomla version -- : last
-- PHP version -- : last
when i select a product in the cart, Instead of remaining on the products page, the module displays the 1 step of checkout.
I would like to stay on products page, and click on cart first to go to checkout.
You can test it at www.cpnt2017.fr/index.php/adherer
Any idea to fix it ?
Alain
Alain
9 years 4 months ago #274210
Replied by nicolas on topic Problem direct checkout after selecting a product
Since you have the "add to cart legacy" setting activated in the HikaShop configuration (and thus you're using the old add to cart system of HikaShop), you can change the setting "After a product is added to the cart" below that "add to cart legacy" setting to "Always stay on the same page", or "Stay and display a popup notice" and that should do it.
9 years 4 months ago #274246
by cpntnat
Replied by cpntnat on topic Problem direct checkout after selecting a product
Sorry, I missed this option !
It's ok now
It's ok now
