Order unit price and subtotal not shown
9 years 1 month ago - 9 years 1 month ago #279108 by Ziegfried
-- url of the page with the problem -- : www.moonshine.co.nz
-- Joomla version -- : 3.3.6
-- PHP version -- : 5.4.45
-- Browser(s) name and version -- : Not applicable
-- Error-message(debug-mod must be tuned on) -- : Not applicable
I have recently updated to the latest version of Hikashop and after the update, the unit price and subtotals are not shown in the back end order information or the "Summary of the Order" email message. When you specify multiple quantities, then no calculation takes place and a zero amount is forwarded to the payment gateway. Only the shipping cost is forwarded to Paypal.
Assistance with this will be appreciated.
Last edit: 9 years 1 month ago by Ziegfried.
9 years 1 month ago #279146 by nicolas
I don't see why it would do that.
Please click on the "check database" button of the HikaShop configuration, it might help.
Also, try switching off the "checkout legacy" setting of the HikaShop configuration in order to use the new checkout system of HikaShop. It might circumvent the problem.
9 years 1 month ago #279186 by Ziegfried
I have done everything as suggested but still the same problem. I have deactivated all legacy settings and all tests in the Check Database were OK.
I can give you admin access to the back end if you want.
9 years 1 month ago #279235 by nicolas
Yes, we'll need a backend and FTP access to the website in order to look at the issue.
9 years 1 month ago #279274 by Ziegfried
Thank you. I have mailed the login details.
9 years 1 month ago #279344 by nicolas
The issue is that you've installed and enabled the plugin "HikaShopCustom Quantity Weight plugin" without configuring a custom field for it. So since it's not properly configured, it mess with the products prices.
I've disabled it for you and it works fine now.
Please note that such personal support is only for commercial editions of HikaShop normally...
The following user(s) said Thank You: Ziegfried
9 years 1 month ago #279363 by Ziegfried
Thank you for your assistance with this. I greatly appreciate it.
