Tax of product not shown correctly in order items
9 years 3 weeks ago #281825 by nuntius
-- Joomla version -- : 3.8.1
-- PHP version -- : 7.0
-- Browser(s) name and version -- : Chrome 69
Moved from here: www.hikashop.com/support/forum/19-hikama...-in-order-items.html
When I order an item with the 6% TAX associated with it, it shows correctly in the checkout and in the order itself in the back-end. See the screenshots attached.
When I edit the order in the back-end it selects the 0% Tax category, but I am not sure why. (See screenshots).
When I look into the database, the initial value of "order_product_tax_info" is this:
a:1:{s:13:"0000_00000001";O:8:"stdClass":18:{s:11:"taxation_id";s:1:"1";s:12:"zone_namekey";a:1:{i:0;s:23:"country_Netherlands_150";}s:16:"category_namekey";s:11:"default_tax";s:11:"tax_namekey";s:8:"BTW Laag";s:18:"taxation_published";s:1:"1";s:13:"taxation_type";s:0:"";s:15:"taxation_access";s:3:"all";s:19:"taxation_cumulative";s:1:"0";s:18:"taxation_post_code";s:0:"";s:19:"taxation_date_start";s:1:"0";s:17:"taxation_date_end";s:1:"0";s:22:"taxation_internal_code";s:1:"0";s:13:"taxation_note";s:0:"";s:16:"taxation_site_id";s:0:"";s:17:"taxation_ordering";s:1:"0";s:8:"tax_rate";s:7:"0.06000";s:9:"zone_type";s:7:"country";s:10:"tax_amount";d:0.68999999999999995;}}
When I alter the value to the 6% Tax category manually, the value of "order_product_tax_info" changes to:
a:1:{i:0;O:8:"stdClass":18:{s:11:"taxation_id";s:1:"1";s:12:"zone_namekey";a:1:{i:0;s:23:"country_Netherlands_150";}s:16:"category_namekey";s:11:"default_tax";s:11:"tax_namekey";s:8:"BTW Laag";s:18:"taxation_published";s:1:"1";s:13:"taxation_type";s:0:"";s:15:"taxation_access";s:3:"all";s:19:"taxation_cumulative";s:1:"0";s:18:"taxation_post_code";s:0:"";s:19:"taxation_date_start";s:1:"0";s:17:"taxation_date_end";s:1:"0";s:22:"taxation_internal_code";s:1:"0";s:13:"taxation_note";s:0:"";s:16:"taxation_site_id";s:0:"";s:17:"taxation_ordering";s:1:"0";s:8:"tax_rate";s:7:"0.06000";s:9:"zone_type";s:7:"country";s:10:"tax_amount";s:7:"0.69000";}}
It seems the initial value is not stored correctly for some reason, even though the amount is registered correctly.
Is there a way to correct this? I hope you can help me out here!
9 years 2 weeks ago - 9 years 2 weeks ago #282007 by Philip
First I have to say that answer you was quite difficult to understand because we don't see the issue you wanted to show us.
Now, I think I get it, but maybe I'm wrong, let's see this together with screenshot :
- Here, an order from my localhost test site :
You can see that as you have yourself good tax name, and value is associated to order.
But if you go for edit your order, you have a form with some options, and among this you have pre-selected tax option, like any form you can have in other setting page, and of course this pre-selected option isn't associated with your order.
Hope this will make you thing clear for you.
Last edit: 9 years 2 weeks ago by Philip.
9 years 2 weeks ago #282047 by nuntius
Hello Philip,
Perhaps I am not explaining it correctly. But it seems something is wrong with the Tax association.
This is my product:
When a customer orders this product, this is the order:
It looks correct, but when I edit the item in the product list it shows different tax selected (0% instead of 6%)
In the database it shows:
The VAT number is correct, but the selection is wrong (should be 6%. When I change it to 6% and save it, it shows correctly:
In the database:
The difference of the database-field "order_product_tax_info" value is that the 0 has been changed to "0000_00000001" and that is probably the cause why it's not selected correctly in the edit form.
I guess this is a bug?
Cheers,
Teeuwis
9 years 2 weeks ago #282110 by nicolas
It looks like a bug yes.
Try changing the line:
<?php echo $this->ratesType->display( "data[order][product][tax_namekey]" , @$this->orderProduct->order_product_tax_info[0]->tax_namekey ); ?>
<?php echo $this->ratesType->display( "data[order][product][tax_namekey]" , reset($this->orderProduct->order_product_tax_info)->tax_namekey ); ?>
in the file administrator/components/com_hikashop/views/order/tmpl/edit_products.php and that should help.
Let us know how it goes.
8 years 10 months ago #286097 by nuntius
Just quick note, it seems to fix the issue!
Cheers,
Teeuwis
8 years 10 months ago #286105 by nuntius
Thanks Nicolas, that fixed the problem!
8 years 10 months ago #286098 by nicolas
Thanks for the feedback !
