How to custom order product lines in a order
8 years 7 months ago #291352 by PeterChain
-- Joomla version -- : 3.8.2
There is some way to order the order product list by a customized column?
For example, I want to order by product_code.
Can I do it by configuration or I have to do it by customizing some class?
Thanks in advance.
Victor
8 years 7 months ago #291357 by Mohamed Thelji
Hello Victor,
Sure, you'll just have to use the "Ordering field" option of your product listing content menu's configuration page, and set it to "product_code".
Best regards,
Mohamed Thelji.
8 years 7 months ago #291395 by PeterChain
Hi again,
Thanks for the answer, but I was referring to the product list view in a single order view not in the product list.
Victor
8 years 7 months ago #291408 by Mohamed Thelji
Hello Victor,
In that case, can you show us some screenshots of where you want to sort your products so that we can directly tell you which option to use or which file to edit ?
Thank you.
