- Thank you received: 2
Problem with some items not counting correctly
8 years 3 months ago - 8 years 3 months ago #295876
by iamalive
Problem with some items not counting correctly was created by iamalive
kuenzli-schuhe.ch
-- Joomla version -- : 3.8.10
-- PHP version -- : 7.1
Some products display a "RESERVED" instead of "IN STOCK"
See the attached images.
I can't work out why this is so. Apparently when someone adds a reserved item it should generate an email to tell someone that a customer wants this item, but nothing happens.
Last edit: 8 years 3 months ago by iamalive.
8 years 3 months ago #295877
Replied by nicolas on topic Problem with some items not counting correctly
This looks like a translation issue because in French and English I do get the message "2 items in stock" (or the equivalent in French) on that page:
monosnap.com/file/ntinT3L2xFjfSz0iDz0Cw0nBkH6mBX
8 years 3 months ago #295905
by iamalive
Replied by iamalive on topic Problem with some items not counting correctly
I've checked the language file and the string I found is : X_ITEMS_IN_STOCK="%s reservierbar"
I've changed that to X_ITEM_IN_STOCK="%s Stück auf Lager"
However, where does the original "Stück auf Lager" come from in the other items? I looked for this string which was already present (see the attachment in my previous message) and couldn't find it anywhere. Other than the main language file, where else can I look to find that string?
My issue is this: there were two different messages being generated by the two example products, apparently by the same string! That can't be the possible. So where is that message coming from?
- Thank you received: 1778
8 years 3 months ago #295908
by Mohamed Thelji
Replied by Mohamed Thelji on topic Problem with some items not counting correctly
Can you give us 2 link where you have 2 different translation version of the "X_ITEMS_IN_STOCK", so that we can at least check the page HTML code to properly advise you. Thank you.
Best regards,
Mohamed Thelji.
Best regards,
Mohamed Thelji.
8 years 3 months ago #295949
by iamalive
Sure:
Wrong term only in German, found in de-DE.com_hikashop.ini
kuenzli-schuhe.ch/de/shop-de/kstyleshop/.../category_pathway-17
No term at all
Correct term, not found in de-DE.com_hikashop.ini
There's something weird going on. I'm perplexed (is there an emoji for that?)
David
No term at all
David
8 years 3 months ago #295970
by Mohamed Thelji
Hello David,
Your issue is coming from the fact that their is 2 translation key that are used :
- "X_ITEM_IN_STOCK" when only one item is in stock
- "X_ITEMS_IN_STOCK" when more than one item are in sock
You should use both of them.
Best regards,
Mohamed Thelji.
Best regards,
Mohamed Thelji.
