Re-use, re-sell, re-rent products
8 years 1 month ago #298317
by hans1961
Re-use, re-sell, re-rent products was created by hans1961
Suppose I would like to sell four different products, which all need to be specific: each product needs to have a unique (customer specific) code.
After usage (one week) the products will be returned to the shop for re-use a year later. Customers need to be able to re-buy or re-rent their own product via the webshop. Is this somehow supported by (modules of) Hikashop?
- Thank you received: 1778
8 years 1 month ago #298322
by Mohamed Thelji
Replied by Mohamed Thelji on topic Re-use, re-sell, re-rent products
There's actually no option to support the rent of products, so the solution will be to either do it "manually" by using Hikashop options and by manually updating your product stock / price, or directly develop the features you need using custom codes.
Kind regards,
Mohamed Thelji.
Kind regards,
Mohamed Thelji.
The following user(s) said Thank You: hans1961
Time to create page: 0.042 seconds
