Front-end print invoice not working unless changing to Cancellable order
- Bananajohn
7 years 6 months ago #306778
by Bananajohn
Good afternoon,
today I bought Hika Shop essential and I found a problem. In the customer area when placing an order and confirming it, the button Print Invoice does not react at all (image 1). However by chance I tried to change the configuration in Order statuses to Cancellable (image 2, showing the cancel order button at front end) and suddenly the pop-up window appears. However I don't want to have to Cancellable order status at all, therefore I am asking, whether somebody knew, where is the problem?
Thank you
Best regards
Jan
Thank you
Best regards
Jan
7 years 6 months ago #306781
Replied by nicolas on topic Front-end print invoice not working unless changing to Cancellable order
I'm not able to reproduce the problem with the same configuration on our end. So there must be something else at play on your website.
Could you provide a link to that page, along with a test user account so that we can reproduce the issue ?
That will allow us to analyze the situation.
Also, which browser are you using ? If you use another browser, do you still have the problem ?
- Bananajohn
7 years 6 months ago #306798
by Bananajohn
Replied by Bananajohn on topic Front-end print invoice not working unless changing to Cancellable order
website: www.ipraqua.cz
click on e-shop
username: test
password: test_account
There are 2 orders now, one created and second confirmed. It is impossible to click on the print invoice button. However, if even in the created status I click on cancellable, then it works everything fine, so for now the solution is to have a cancellable created order.
Jan
click on e-shop
username: test
Jan
7 years 6 months ago #306800
Thank you. We were able to find the issue thanks to the access you provided.
The "print invoice" button in the "actions" dropdown of orders might not work in some cases because of a side effect of the move from the "allow users to print their invoice" option of the configuration to the "print invoice" column of the System>Order statuses menu.
And you wouldn't see the problem if you updated HikaShop with that old setting activated. That's why I couldn't reproduce the problem.
I've added a patch on our end for that problem. Download the install package on our website and install it on yours and it will then work.
The following user(s) said Thank You: Bananajohn
