Manual order status without stock management
7 years 4 months ago #308228
by Urbinati
Dreamlord Press
www.dreamlordpress.it
Roleplaying Games in the new era
Manual order status without stock management was created by Urbinati
-- HikaShop version -- : 4.1.0
-- Joomla version -- : 3,9,8
-- PHP version -- : 7.3.6
We need new order statuses, both with or without invoice, but without stock management (stock management remains with default statuses).
We tried to put some new statuses up but stock gets modified as soon as we insert products in the new order with the new status.
Is it a problem of Hikashop Systrem configuration (Update stock on confirmed; Clear cart on created) or is it a wrong order status definiton (pubblicated, only flag is statistics)?
Thank you,
Thank you,
Dreamlord Press
7 years 4 months ago #308229
Replied by nicolas on topic Manual order status without stock management
The statuses will only be taken into account if they are enabled under the "invoice" column of the System>Order statuses menu.
That's mentioned when you hover on that column name title.
And that's only the case if you set the Update stock on confirmed in the HikaShop configuration. If you set it to created, then the stock will change when the order is created and the stock won't change until the order is cancelled (the statuses enabled in the "cancelled" column).
7 years 4 months ago #308247
by Urbinati
Dreamlord Press
Replied by Urbinati on topic Manual order status without stock management
So,
Which is the right configuration to have a status to use manually, without invoive creation, and without stock change?
- System/Main/Product: Update stock on confirmed - Yes/No
- System/Main/Cart: Clear Cart on order - Confirmed/Created
- System/Order Statuses: columns to flag
At the moment, the custom Order Status with "Update stock on confirmed" = Yes and "Invoice" column not flagged is updating stock.
I would need to have custom Order Statuses to use in the backend, to add sellings (both with or without invoice creation) made outside the shop, without altering shop's stock.
Thank you very much,
Dreamlord Press
7 years 4 months ago #308248
Regarding the options "Update stock on confirmed" and "Clear Cart on order", you can configure them however you want/need.
When you create your custom order statuses in the System>Order statuses menu, you just need to make sure that they aren't enabled under the "invoice" and "cancelled" columns. Then, they won't be taken into account for the stock of the products.
