Shopping cart after order is not empty
6 years 10 months ago #314578
by komir
Shopping cart after order is not empty was created by komir
Hello, need help.
After the user makes an order, in their shopping cart all ordered items are still inside the shopping cart. How to make, after ordering users shopping cart to be emptied?
Thank you
Thank you
6 years 10 months ago #314603
Replied by nicolas on topic Shopping cart after order is not empty
Check the setting "clean cart after order is" in the HikaShop configuration. If it's set to "created" then the cart will be emptied directly after the order is created.
6 years 10 months ago #314625
by komir
Replied by komir on topic Shopping cart after order is not empty
Hello it is set up to "created". After my test order items are still in a shopping card.
Thank you
Thank you
6 years 10 months ago #314631
Then the issue is probably that you have several carts assigned to your user account and when you finished the checkout the next cart got loaded.
To do your test, please first delete all the carts of your user account via the Customers>Carts menu. Then, do a checkout of a cart on your website and it should work fine.
4 years 10 months ago - 4 years 10 months ago #338634
by sadaf3d
Replied by sadaf3d on topic Shopping cart after order is not empty
hi.
I have similar problem but for me , i use mass action for on after order confirmed redirect to some joomla menu. i use this code in Run PHP code box:
and when i disable that , the cart empty successfully.
i can set return url in payment method but if user use 100% coupon it is not work.
even i use that code in the plugin but the problem is still and cart not empty.
i write my redirect code at the end of checkout/after_end.php and it is work without problem
$url="index.php?Itemid=337";
JFactory::getApplication()->redirect(
JRoute::_($url, false)
Last edit: 4 years 10 months ago by sadaf3d.
4 years 10 months ago #338644
The cart is normally cleared in the controller of the after_end view file. So if you use a mass action to redirect the user somewhere after the order is created/confirmed, you'll skip the after_end controller.
So yes, the solution is indeed to add instead the redirect in the after_end view file, which is displayed just after the after_end controller so that the cart will be cleared before your redirect.
4 years 10 months ago #338901
by sadaf3d
excuse me nicolas.
it seems i have mistake. my code not work in after_end.php . i must use my redirect code at the end of end.php. i don't understand their different.
4 years 10 months ago #338916
Normally, the checkout workflow goes like this:
click on "finish" -> order is created -> "end" view file is displayed with the redirect code of the payment plugin to go to the payment page of the payment gateway -> user enter his credit card information and validates -> the user is redirected back to the "after_end" view file -> the cart is cleared in the controller -> the "after_end" view file is displayed with the thank you message.
However, some payment plugins work differently:
click on "finish" -> the payment is processed directly with the credit card information already filled in during the checkout -> order is created -> the cart is cleared in the controller -> the "end" view file is displayed with the thank you message.
And some other payment plugins might have a different behavior, these are just the main ones.
I don't know which payment plugin you're using so I'm not sure what is the situation.
The following user(s) said Thank You: sadaf3d
