Invoice format not same in front and back end
6 years 5 months ago #320458 by softdune
-- url of the page with the problem -- : www.softdune.com
-- Joomla version -- : 3.9.18
-- PHP version -- : 7.3.18
I did some customization in the back orders (added text and logo's) using invoice.php
From the front end the users can print the invoice through My Orders/Actions/Print Invoice
Is there a way that this front end invoice is the same as when created from the back end?
6 years 5 months ago #320461 by nicolas
Yes, you need to do the same customization in the order / show.php view file for your frontend template.
Note that the customization might vary since on your frontend, you have the CSS of your template to take into account when you do CSS customization.
Otherwise, if you use the PDF invoice plugin, both frontend and backend will use the same base for the PDF. Note however, that it bases itself on again another view, which would have to be customized again if you were to use it.
The following user(s) said Thank You: OnslaughtUK
6 years 5 months ago #320474 by softdune
I'm considering taking the PDF Invoice plugin.
If I understand you correctly this is not taking the invoice.php as basis to create the invoice output.
If so, what is the used base?
just a thought: why is the OOTB not using all the same base to create the invoices. It would be much easier to maintain.
6 years 5 months ago #320483 by nicolas
Yes, it's using its own invoice.php. You'll find it in the folder plugins/hikashop/attachinvoice/attachinvoice/ after you install the plugin so you'll be able to customize it there.
I don't know what you mean by OOTB.
The reason it uses two different files for the invoice is because we're allowing you to have a template override and thus the invoice layout is a normal view file. In that case, the way the MVC system of Joomla works, you can't use a backend view file on the frontend and vice-versa. So we had to have to different view files.
6 years 5 months ago #321063 by softdune
Just an additional question on this before I customize the plugin invoice.php file in plugins/hikashop/attachinvoice/attachinvoice/
Do I do this directly in the above (with FTP) or is there a possibility to do the customization from within Hikashop through display/views ?
ps: sry about the OOTB abreviation. It stands for Out-Of-The-Box (= how the software is delivered standard)
6 years 5 months ago #321093 by nicolas
You can do it through Display>Views so yes you can do it via FTP.
PS: thanks for the explanation. My mother tongue is not English, so I'm not well versed in such abbreviations.
