Points Total Not Updated
6 years 2 months ago #323450 by davec
-- Joomla version -- : 3.9.21
-- PHP version -- : 7.4.9
I have a clients site where a customer has made a purchase and used points to make part of the payment. However when checking, the points have not been deducted.
Order status is set to confirmed. After the order was confirmed the client applied a a status of Confirmed/Ready.
If the order status is changed would this add the points back onto the order?
On the order status the confirmed has the radio button confirmed checked. On the confirmed/ready this is not the case, please see the screenshots.
David
6 years 2 months ago #323457 by nicolas
Replied by nicolas on topic Points Total Not Updated
You need to edit the settings of the user points plugin via the Joomla plugins manager:
monosnap.com/file/POBd2HXPSvE4bMFhI1hseh3VudJXw9
There, you'll see a "valid order statuses" setting.
There, you can enter the list of order statuses to take into account to give the points to the customer.
I suppose that this Confirmed/Ready order status is not listed there.
6 years 2 months ago #323536 by davec
Replied by davec on topic Points Total Not Updated
Hi Nicolas
the payment plugin itself has a Verified Status of Confirmed. The client gets the points added to their account.
An order was placed and the customer used points to make part of the payment. I would have expected this to remove the points or are you saying I also need to add the statues to the points plugin so that points are deducted if used?
David
6 years 2 months ago #323547 by nicolas
I think I read your message too fast. I thought the issue was that points were not gained after an order, and not that the points were not deducted when using points for the payment.
In that case, could I get a screenshot of all the settings of your user points payment method so that I can better a better understanding of the situation ?
And what is used as the payment method ?
6 years 2 months ago #323563 by davec
Hi Nicolas
screenshots attached.
The rest of the payment was made using PayPal.
David
6 years 2 months ago #323568 by nicolas
I don't see anything out of place on the screenshots.
I think I'll need to check the situation directly on your backend.
Could you provide an access to it along with the order number of an order with the issue via our contact form ?
6 years 2 months ago #323577 by davec
Hi Nicolas
I have sent the info
David
6 years 2 months ago #323686 by davec
Hi Nicolas
I sent over details as requested last week and just wondered if you had been able to look at this for me?
David
6 years 2 months ago - 6 years 2 months ago #323710 by Philip
Replied by Philip on topic Points Total Not Updated
Please double check your references you sent us, so far we have an error message when we try to use it.
regards
Last edit: 6 years 2 months ago by Philip.
6 years 2 months ago #323733 by davec
Hello Nicolas
Do you meant the login details?
David
6 years 2 months ago #323785 by nicolas
We received your backend access and were able to check your settings.
I think that the issue might be related to the "Valid order statuses" setting of the user points plugin (via the joomla plugins manager), which is empty instead of containing "confirmed,shipped".
I've changed it for you and it should hopefully work better.
Please check if that helps.
If not, then we'll need a FTP access and precise instructions to reproduce the problem on your website (with a 100% coupon code and a user account with points for example).
6 years 2 months ago #323816 by davec
Hi Nicolas
thanks for the update. I will check this and get back to you if I need to.
David B)
6 years 2 months ago #323861 by davec
Hello Nicolas
this hasn't worked and there is a very odd behaviour too.
I created an order and then used the points as part of the payment. The points were deducted but on order created (Using the Check payment plugin). I then updated the order to confirmed/ready via the admin and the points were added back on. Finally I updated the order this time to just confirmed and it added 20 points back on not the full 50.
I will now send over FTP & site login details so you can take a look please. This is quite urgent as the site is live.
David
6 years 2 months ago #323971 by davec
I just wondered if this has been looked at yet?
David
6 years 2 months ago #324169 by davec
Hello Nicolas
I am very disappointed in the lack of response to this post and the issue with points deducting and then being re-added. The lack of a reply really does not inspire confidence in the Hikashop component.
I sent over login info and details via the contact form I followed this up approx a week ago again via the contact form and also 12 days ago on this forum. I have an unhappy client and no response from the you or anyone else from the development team.
If further information is required can you please update this post or email me direct via the email address I used on the contact form.
David
6 years 2 months ago #324173 by Philip
We were unable to get the root issue and so we processed a deeper analysis, especially in your back-end configuration and maybe there are think that can leads to your current issue, but can be sure of it, follow me step by step :
1. We don't find this order Status ("Confirmed/Ready") in your order statuses listing.
2. Note that in your Hikashop UserPoints Plugin, and in the "Valid order statuses" field you have to enter the Namekey, not the Name.
3. Can you provide a detailed step by step process on how do you test that your points is added AND deducted, and so we can
reproduce ourselves on your website, and we insiste on the fact that your step by step have to be detailled, to check that the way you want to use
it fit your backend configuration please.
Awaiting news from you to better to get the root issue.
regards
6 years 2 months ago #324186 by davec
Hello Philip
Thanks for your reply. The order status had been changed by the client and I was not aware of it, sorry.
So just to clarify. Every order status that is used needs to be in the points plugin using the namekey to prevent the points being added back on?
In brief when the order was first placed & confirmed the points were deducted, when the status was changed they were added back on again. If you can confirm the above point I will carry out another test. If this still doesn't resolve it I will create a screenshot video so you can see what the steps are.
David
6 years 1 month ago #324215 by Jerome
Replied by Jerome on topic Points Total Not Updated
The "valid order statuses" setting of the plugin must be configured only if you do have special order statuses as "confirmed" orders.
But, if in your HikaShop "order status" configuration, you do have the "invoice" state for all status which are valid for the points ; best is to let the plugin setting empty.
The other point is that you need to enter the order status "namekey" in the plugin settings.
I don't think that your "Confirmed/Ready" status do have that namekey set-up in HikaShop ; maybe something like "confirmed_ready" instead.
When dealing with order statuses, we prefer to use a namebox selector (like in the HikaShop configuration panel), but that setting in the points plugin should be let empty most of the time and is really there to handle very specific cases.
6 years 1 month ago - 6 years 1 month ago #324241 by davec
Hi Jerome
as you can see from the attached screenshot there a number of order statuses. You can only set one confirmed.
So are you saying all of the other order statuses should be in the plugin or none at all? So does invoice need to be ticked for the relevant statuses so that the points are not credited back?
Basically what has happened is after the order is paid and confirmed via Stripe or PayPal the points are deducted. However when the status was changed to Confirmed/Holding (Namekey confirmedholding) for instance the points were added back to the account.
David
Last edit: 6 years 1 month ago by davec.
6 years 1 month ago #324483 by davec
It is now over a week and yet again I have not had a response to my last post. Not only that but the information given seems to conflict.
Over 3 weeks ago I was told the following by Nicolas:
"I think that the issue might be related to the "Valid order statuses" setting of the user points plugin (via the joomla plugins manager), which is empty instead of containing "confirmed,shipped."
I then had a reply from Philip telling me to use the namekey. Then 2 days later a reply from Jerome telling me to leave it empty. The screenshots I sent after that reply indicated that I have a number of specific Order Status options.
The topic was started 5 weeks ago and to date I am no closer to getting it resolved. Not only that but I have a client asking me when this will be fixed. I did provide admin access and steps to replicate the issue via an email. If that wasn't enough then I cannot understand why I wasn't contacted?
To be honest I am very fed up with the lack of communication. Can one person not take hold of this problem and work with me to get it resolved?
David
Time to create page: 0.131 seconds
