Problems with receiving emails
5 years 2 weeks ago #336559 by Awards4u
-- url of the page with the problem -- : www.awards4u.ca/
Problems with email and I haven't changed anything. I'm not getting any emails and I'm not sure why.
Every time someone orders I'm not getting an email. Please see attached.
5 years 2 weeks ago #336564 by Mohamed Thelji
Are you able to send Joomla / Hikashop emails from your website ?
If you're still not receiving emails, can you check the menu "Hikashop-> Customers-> Emails history" to tell us if emails are sent ?
If yes, then HikaShop sent them to the email server but the email server was not able to send them to the recipient email server.
So you'll have to check the logs of the email server to understand why this is happening.
You'll probably have to contact your hosting support with a screenshot of the details of one email from the history that wasn't delivered so that they can tell you what's wrong.
It's probably something related to the settings under the Emails section of the HikaShop configuration.
Kind regards,
Mohamed.
5 years 2 weeks ago #336586 by Awards4u
I sent an image of the email configuration. Please see if you see anything. Host can't find anything.
I also sent the other pictures as well. Please let me know if you see anything wrong. How would I find the problem?
Mohammed
5 years 2 weeks ago - 5 years 2 weeks ago #336594 by Philip
Can you provide as well a screenshot of your email listing, please ?
=> From Main HikaShop Configuration, System dropdown => Emails
Plus, by the past, have your emails functioned well, and if so, when do you think the emails started to function poorly ?
Joomla update ? by HikaShop ? or other update like for example php ?
Awaiting your elements and hope this will help to progress on your subject.
Last edit: 5 years 2 weeks ago by Philip.
5 years 2 weeks ago #336608 by Awards4u
This problem just started on the week end. Before that it was working fine. I haven't done anything different. No updates.
5 years 2 weeks ago - 5 years 2 weeks ago #336613 by Philip
It seems that you have forget the email listings screenshot, I think that if you add the order statuses listing would be even better, and in any case could help us to go further.
Awaiting your elements.
