sub zone in persian language has some problem.
4 years 6 months ago #341538 by sadaf3d
hi
how to get you correct list of sub zone list in persian language?
i understand that i can change subzone from
******.com/administrator/index.php?option=com_hikashop&ctrl=zone&task=edit&cid[]=101
but i want get you correct spelling and translate of subzons.
4 years 6 months ago #341540 by nicolas
If you could provide a list of all the sub zones that would be great (if you can include the english name for each too that would be even better).
I can then check with what we have to add/remove/mofidy zones and check with wikipedia (if you have a wikipedia link with the zones that's great too).
And if you have comments on some of the zones do not hesitate to add that too. For example, if a zone in HikaShop has actually been split in several zones then it's great to know about it so that I can better adapt the code in HikaShop.
Now, on how to provide the list, it's up to you.
You could just write it in a message directly here, or write it in a google sheet and provide a link to it for example.
4 years 6 months ago #341713 by sadaf3d
please see this file and also i linked them to wikipedia. thank you
4 years 6 months ago #341730 by nicolas
Thank you.
I checked but we already have the full list in HikaShop. In fact, we've updated the list with HikaShop 4.2.1. So if you install a new HikaShop of that version or newer, you'll automatically get that list.
Still, this allowed me to add the english translation to the provinces. It will be easier to find them for us in the future.
Also, I can see that their order is not correct.
However, I'm not sure which is the correct order of the provinces so that someone from Iran would be able to find them easily. And the list you provided is ordered based on the English name. Could you provide the list with the order someone from Iran would be familiar with so that I can order the provinces in that same order ?
4 years 6 months ago #341817 by sadaf3d
nicolas wrote: Hi,
Thank you.
Hi again
but your list have some little problem in persian lanuage where you can see in the attached file:
in this list hikashop use " ي " but in correct type must use " ی "
in the excel file i attached here this is correct and also you can see in this link:
fa.wikipedia.org/wiki/%D9%81%D9%87%D8%B1...8C%D8%B1%D8%A7%D9%86
nicolas wrote: Hi,
the attached file has new order from previous file and this new file has more familar order for iranian people and also you can see this order in above wikipedia link in current post.
4 years 6 months ago - 4 years 6 months ago #341827 by levelup
Hi nicolas. let me answer this.
اول وارد قسمت مناطق شو.
اون جا تنظیمات filter option رو طبق شکل زیر انجام بده.
مناطق مربوط به ایران رو میاره.
روشون کلیک کن و ویرایش شون کن.
Life is the unique stage of our art. Everyone sings their own song and leaves the stage. The stage is always permanent. Blessed is that song that people remember.
Last edit: 4 years 6 months ago by levelup.
4 years 6 months ago - 4 years 6 months ago #341829 by sadaf3d
levelup wrote: Hi nicolas. let me answer this.
داداش ورود نکن. نیکولاس داره هسته هیکاشاپ رو تغییر میده. من متوجه هستم که از کجا باید ویرایش کنم. توضیحاتی که من دارم میدم برای تغییر در هسته هست که در ریلیز های بعدی هیکاشاپ این مشکلات رو نداشته باشه. این تاپیک رو ادامه نده بذار کار به نتیجه برسه. ممنون
Last edit: 4 years 6 months ago by sadaf3d. Reason: RTL problem
The following user(s) said Thank You: levelup
4 years 6 months ago #341820 by nicolas
Thanks. Yes, I've updated all the names in Iranian with what was in your excel file so they should all be correct.
I've also reordered them so it should be all good now.
Thanks for sharing !
The following user(s) said Thank You: sadaf3d, levelup
