- Thank you received: 3
Setting next order and invoice numbers
- studiocurci
3 years 5 months ago #352415
by studiocurci
Setting next order and invoice numbers was created by studiocurci
-- HikaShop version -- : 4.7.3
-- Joomla version -- : 4.2.9
-- PHP version -- : 8
please in configuration how can I set next order number, for example 100 (incremental, then 101 and so on) and next incremental invoice number, for example 50?
I suppose I have to fill in some way the fields Order number format and the field Invoice number format but I don't know the syntax.
Thank you
Francesco
Thank you
Francesco
3 years 5 months ago #352418
Replied by nicolas on topic Setting next order and invoice numbers
So, first, you should configure the order / invoice number formats.
For the order number format, set it to {order_id}
For the invoice number format, set it to {order_invoice_id}
Then, if you want the next order number to be 100, you need to set the auto_increment value of the hikashop_order table to 100 in your PHPMyAdmin: www.hikashop.com/forum/orders-management...et-order-number.html
For the invoice number, if you want the next number to be 50 you need to open the hikashop_order table in your PHPMyAdmin, edit an old order, and change the order_invoice_id to be 49.
- studiocurci
3 years 5 months ago #352456
by studiocurci
Replied by studiocurci on topic Setting next order and invoice numbers
Hi I did it, thank you.
It could be nice in the next hikashop version to add a simple feature in Joomla backend.
Something like a field for the next invoice number.
Thank you, regards
Francesco
Thank you, regards
Francesco
3 years 5 months ago #352482
Thank you for your feedback.
