Best selling products statistic does not work prop
Hi i noticed something wrong on the best selling products statistic.
I have the total amount of some products too big. I have not sold all those products!
Do you have notice of the same issue with other users?
If not, could you explain better how does that type of statistic works?
For example when the amount is update?
If i try to make an order just for a test i don't see the amount update.
my site with Hikashop
www.lacasettabio.it
Thanks to give us a screenshot of you report configuration in order to try to reproduce the issue on our end.
The amount should be updated once the order has a confirmed status.
here you are the screenshot.
www.lacasettabio.it
In the filter of this report you don't have selected an order status, so all the products of all the orders statuses are displayed.
Even products in cancelled, or created orders, so as you said it don't represent the sol products.
You just have to add more conditions in the filters.
it was setted on shipped.
On the screenshot i did not scroll down the menù.
www.lacasettabio.it
now i tested better it.
I buy two pcs of a same product, the total amount is 26 Euro.
The total amount on the statistic, before the purchase is 490 Euro.
When i set the order on shipped the amount on the statistic is 672 Euro!!!!!
if i set the order on cancelled the statistic amount come back on 490 Euro.
So the system adds 182 Euro insted of 26 :ohmy:
www.lacasettabio.it
Can you please edit the file "administrator/components/com_hikashop/helpers/widget.php" and replace
i'm sorry but i don't have that file, as you can see on the screenshot attached here.
If it can to help you, the product where i had the test is that: www.lacasettabio.it/negozio-online/prodo...libro-vendita-online
www.lacasettabio.it
Jérome was talking about the file "administrator/components/com_hikashop/classes/widget.php"
But I find the file already modified. Namely in the version hikashop_business_v2.3.3_2014-09-29_07-13-52 the change was made
www.lacasettabio.it
I'm sorry, the result does not change
www.lacasettabio.it
i tried to create an identical new gadget.
Now when i have the tests
on the old one i have the issue
on the new one seems to work.
www.lacasettabio.it
on the Display box, please?
www.lacasettabio.it
i red the tutorial...
but the instrution are
Date Type: Choose here the date type used to generate the report. :blink:
I'd like to know what is the difference between:
> Created
> Last Modified
www.lacasettabio.it
- Thank you received: 1778
Sorry for the late reply, the Date Type option will enable you to choose the date which will be used to display your orders :
- Created : will display your orders on the Order creation date
- Last modified : will display your orders on the Order last modified date (the last time you modified your order).
