unpublish products with variants with zero stock
13 years 1 month ago #119018 by Boudewijn
-- url of the page with the problem -- : dodowear.nl
-- HikaShop version -- : 2.2
-- Joomla version -- : 2.5
-- PHP version -- : x.x.x
we work with products with variants
As most of the products are seasonly (only delivered once) they need to be unpublished when sold out.
So when all variant of a product have no stock anymore the parent product should become unactive.
Up until now I do this manualy with import and export in excel or walking trough the website.
But as you can understand this is a lot of work.
So I was wondering if you could tell me a simplerer and more time winning method
thanks in advance Boudewijn
13 years 1 month ago #119042 by Jerome
I think you can use the mass action
www.hikashop.com/support/documentation/167-massaction-form.html
13 years 1 month ago #119405 by Boudewijn
Hello Jerome,
It looks like the massaction can help me on this, but I want to be sure if it's working the way I would like.
After reading your documentary on this I have created the your example on out-of-stock.
But now I would like to test it. And I'm bit afraid that the product will be massed up.
In the product database the parent-product are all 0, the stock is on the variant.
Should this batch working correctly. So, move product which have no stock anymore on the variant to a category called out-of-stock.
And is there a way to test this. Something like a report or it shows me the products which will be moved.
I hope the everything is explained it correctly.
If this works this is a very powerfull tool.
13 years 1 month ago #119411 by nicolas
To show which products will be changed, you can remove your action and instead use the action "display the results".
That will display you a list of the elements filtered.
Note that you probably want to have a filter on the product_type column equal to "variant" so that only variants get affected by the modification if that's what you want.
13 years 3 weeks ago #122315 by Boudewijn
previously I mentioned that I get a script error on Massaction.
In the attached file you'll a picture of this message
13 years 2 weeks ago #122576 by Jerome
A problem with my sweety otree library ?
How many categories do you have ?
12 years 9 months ago #137367 by Boudewijn
Last days I have been playing a bit with the massaction tool.
I did some queries. And in chrome it works fine instead of firefox.
Still I would like to get a hint.
What I have created as a report now shows me all variants with 0-stock.
I selected to show on screen. So manualy I can unpublish the product.
But I actualy need to unplubish the parent-product.
How can I manage that?
So summarized: the massaction needs to show all parentproducts where all variants have no stock (=0).
This would help me a lot
12 years 9 months ago #137378 by nicolas
Then that's quite easy. Simply enter the total stock in your main products and the system will adjust the total stock when the variants are bought. Then, you can just have a filter on the product_quantity for main products in your mass action.
12 years 9 months ago #137476 by Boudewijn
Yes I would say also that is simple but all my main product are on 0 or -1 stock.
Then I first need to update the stock of the main product.
Can I do this also in massaction?
12 years 9 months ago #137549 by Mohamed Thelji
Sure, you'll just have to add an "Update values" action and apply it on the "product_quantity" field.
12 years 9 months ago #137566 by Boudewijn
Can you be a bit more specific
Where can I select the option update values?
12 years 9 months ago #137580 by Mohamed Thelji
By creating a new mass action, and using the options under the "actions" tab, for example you can update every quantity field of your products to 10000 like this :
12 years 8 months ago #139524 by Boudewijn
After I have read through the different steps and process I'm not completly convident on the different actions.
I will try to explain.
Nicolas suggested that all parent product should have the total stock of all variants.
Which is not the case in our database.
So you optained to give those product stock by another mass-action.
But then I can only give those product a hard quantity.
For instance 10.
But the when I do a massaction to show all products where the variant has zero stock I don't think that all correct information is there
Perhaps I see wrong
I would expect to see
product_parent_id product_code product_quantity product_published
01234 0 1
01234 01 0 1
01234 02 0 1
And if that's the information: unplublish the parent product
I hope you can tell me how to do so
12 years 8 months ago #139604 by Xavier
Actually you cannot get the total quantity of each variants of a product to change the product quantity.
This is something that you should do before.
To do what you need, I think that you will have to create your own plugin based on the massactions.
A plugin which will get the quantity of each variants of a product, and if this quantity is 0 then unpublish the product.
12 years 8 months ago #139696 by Boudewijn
Hello Xavier,
That is exactly what I would like to have.
But I am not that skilled to program
Who can help me on this?
12 years 8 months ago #139797 by Xavier
I think that the best thing is to post a request on the commercial jobs section of this forum.
This require some development and we are not able to provide this kind of codes on the forum.
12 years 8 months ago #141120 by Boudewijn
Hello Xavier,
Thanks for your reply.
I gonna manage it through my POS system in the store.
There is already a connection between them for my stock.
and pricing.
But it would be nice to have build in something like that in the future
12 years 7 months ago #142095 by Xavier
I have added it on our TODO list :)
The following user(s) said Thank You: Boudewijn
12 years 7 months ago #144003 by Boudewijn
Hello Xavier,
Yesterday I noticed that you have published the new version of hika shop.
In the changlog there was something written on the mass action with variants.
Is it possible to do this query now.
And if so, can you tell me.
Thanks so far
12 years 7 months ago #145298 by Boudewijn
Hello Xavier,
Perhaps you missed my latest reply.
When you have time you can take a look at it
Time to create page: 0.316 seconds
