Removal of Products when importing CSV
12 years 11 months ago #133709 by Prodessa
Currently we are using Hikashop Products Cron Update Plugin to process our articles/products.
As we enabled the option delete products not in CSV you would expect that products will be removed/deleted from our shop.
The current format of the CSV is:
product_code|price_value|categories|categories_namekey|images|product_quantity|product_description|cxp_merknaam|product_name|product_sale_end|cxp_toepassing|cxp_materiaal|product_published|cxp_levertijd|cxp_normale_prijs
The importing is working as it should be!
The removal is however not working despite the configuration of the column names configurations:
Configuration of column names:
product_code:product_code|price_value:price_value|categories:categories|categories_namekey:categories_namekey|images:images|product_quantity:product_quantity|product_description:product_description|cxp_merknaam:cxp_merknaam|product_name:product_name|product_sale_end:product_sale_end|cxp_toepassing:cxp_toepassing|cxp_materiaal:cxp_materiaal|product_published:product_published|cxp_levertijd:cxp_levertijd|cxp_normale_prijs:cxp_normale_prijs
It's rather difficult to troubleshoot or find documentation/examples.
What are the criteria to get is working successful?
12 years 11 months ago #133753 by nicolas
Which version of HikaShop are you using ?
12 years 11 months ago #133767 by Prodessa
Versie HikaShop [1310121420]
12 years 11 months ago #133853 by nicolas
Can you try to change the line:
$query ='SELECT product_id FROM '.hikashop_table('product').' WHERE product_id IN ('.implode(',',$ids).') AND product_type=\'main\';';
$query ='SELECT product_id FROM '.hikashop_table('product').' WHERE product_id NOT IN ('.implode(',',$ids).') AND product_type=\'main\';';
in the file plugins/hikashop/datafeed/datafeed.php and try again ?
12 years 11 months ago - 12 years 11 months ago #134036 by Prodessa
I'm sorry but that doesn't remove the articles that are not in the CSV?
The function uses product_id to check but that is not in my csv file, I have change it to product_code.
What can we check more?
The image attached in first message shows configuration is that correct?
Does the PIPE separator/delimiter influence the behavior?
Last edit: 12 years 11 months ago by Prodessa.
12 years 11 months ago - 12 years 11 months ago #134046 by Prodessa
I have check the code step by step and he never access the highlighted part.
Somehow the contentfile is treated as object but is not.
Should the helper convert it?
$contentFile = file_get_contents($path); if(empty($contentFile)){ $messages[] = 'Could not retrieve the CSV file '. $path; }else{ if(!$helper->handleContent($contentFile)){ return false; } if(!empty($plugin->params['delete']) && [u]!empty($contentFile->products)){[/u] $ids = array(); foreach($contentFile->products as $product){ var_dump($product); $ids[$product->product_id] = $product->product_id; } $query ='SELECT product_id FROM '.hikashop_table('product').' WHERE product_id NOT IN ('.implode(',',$ids).') AND product_type=\'main\';'; $db = JFactory::getDBO(); $db->query($query); $prods = $db->loadObjectlist('product_id'); $todelete = array_keys($prods); $class = hikashop_get('class.product'); $class->delete($todelete);
12 years 10 months ago #134674 by Prodessa
Nicolas?
Any help?
12 years 10 months ago #134760 by Xavier
Can you try to do this thing thanks to the hikashop mass actions ?
In System > Mass Actions, configure a mass action like on this screenshot:
12 years 10 months ago #134772 by Prodessa
I've get a timeout of the browser, should I change something?
12 years 10 months ago #134818 by Xavier
Have you set a limit in the filters ? like on the example start:0 and limit:500 ?
Then execute again the mass action with start:500 and limit:500.
Else if there is too many data, the servers can't process the action.
12 years 10 months ago #134843 by Prodessa
The file is about 380KB
The server responds with limit 500:500 =
Fatal error: Allowed memory size of 268435456 bytes exhausted (tried to allocate 251396073 bytes) in C:\domains\website.nl\wwwroot\administrator\components\com_hikashop\classes\massaction.php on line 1555
Warning: mysqli_ping() [function.mysqli-ping]: MySQL server has gone away in C:\domains\website.nl\wwwroot\libraries\joomla\database\database\mysqli.php on line 190
Is there still a option?
Is it also posible to point to a URL in the massaction?
12 years 9 months ago #138262 by Xavier
Sorry for the late reply, have you solved your problem ?
Do you have the latest version (2.2.3) ?
Thanks to reduce the limit, could you give me the concerned lines regarding the Fatal Error ?
12 years 9 months ago #138263 by Prodessa
I found a way arround it by removing the products directly from the database by a seperate routine.
Did you have a look at the code what I mentioned in my earlier response?
Currently I'm not able to provide but i will try this week.
12 years 9 months ago #138294 by Xavier
We had made few changes on the mass actions.
But not sure that they fix this problem.
