Exporting Products Problem
12 years 9 months ago #134858 by billkarv
I have made a mistake. I have deleted (accidentally) some files from my joomla - hikashop installation. And now when I try to export a specific category by selecting some products and push the export button, hikashop exports all of my products and the columns is a mess.
How can I check if my files are OK?
I don't know exactly which files I 've deleted.
The other things in my shop seem to work properly!
12 years 9 months ago #134918 by Mohamed Thelji
The solution will probably be to download the last Hikashop version through our website, install it, and test it again, so that the Hikashop missing files will be added again.
Note that making a backup is always a good security.
12 years 9 months ago #134944 by billkarv
Replied by billkarv on topic Exporting Products Problem
Reinstalled the Hikashop component and still the same problem.
What options do I have to check to ensure that is all setting the right way?
12 years 9 months ago #135156 by nicolas
Replied by nicolas on topic Exporting Products Problem
Can you provide your exported CSV so that we can see the problem ?
12 years 9 months ago #135170 by billkarv
Offcorse..
12 years 9 months ago #135176 by nicolas
The columns are not a mess on my end with that file. What do you mean ? Could you do a screenshot of when you open your CSV with the issue you're having ?
12 years 9 months ago - 12 years 9 months ago #135238 by billkarv
You are right, did you 've changed something at the export method of the products. At the previews versions of hikashop when I was choose to export only the selected products of a specific category I was took only these products. Now the product ID's starts at the 196 row instead of 2nd row. I want to export only the specific products. Why in shows me all of these categories at the beginning of the document?
Last edit: 12 years 9 months ago by billkarv. Reason: typo
12 years 9 months ago #135258 by nicolas
The system always export all the categories tree first so that if you import the CSV on another website, it will first recreate all the categories if necessary before adding the product(s) that you selected.
12 years 9 months ago #135388 by billkarv
OK then, thank you very much.
Time to create page: 0.199 seconds
