Order of Related Products not kept during import
11 years 4 months ago #209477 by dkmetz@taylorbruce.com
-- Joomla version -- : 3.4.3
-- PHP version -- : 5.5.25
I am updating products, adding related products to each of my products. I would like the related products to show in the order that I enter them... can this be done?
Here is my import:
product_id related
1380 104,106,113,103AF,106AF,118AF,119AF
Related Module settings:
prntscr.com/7wkkca
Order observed (after the import):
prntscr.com/7wknlt
103AF,106AF,118AF,119AF,104,106,113
Order desired:
Dennis
______________
Dennis Kmetz
11 years 4 months ago #209496 by nicolas
The ordering of the related products is indeed not handled by the CSV import.
It can be added quite easily I think.
Change the code:
function _insertRelated(&$products,$type='related'){ $values = array(); $totalValid=0; $insert = 'INSERT IGNORE INTO '.hikashop_table('product_related').' (`product_related_id`,`product_related_type`,`product_id`) VALUES ('; $ids=array(); foreach($products as $product){ if(!isset($product->$type) && empty($product->hikashop_update)){ //copy files from template if any if(@$product->product_type!='variant' && !empty($this->template->$type)){ foreach($this->template->$type as $id){ $value = array((int)$id,$this->db->Quote($type),$product->product_id); $values[] = implode(',',$value); $totalValid++; if( $totalValid && $totalValid%$this->perBatch == 0){ $this->db->setQuery($insert.implode('),(',$values).')'); $this->db->query(); $totalValid=0; $values=array(); } } } }elseif(isset($product->$type)&&is_array($product->$type)){ $ids[] = (int)$product->product_id; foreach($product->$type as $k => $id){ if(!empty($id)){ $id = $this->_getRelated($id); $product->{$type}[$k] = $id; $value = array((int)$id,$this->db->Quote($type),$product->product_id); $values[] = implode(',',$value); $totalValid++; } if( $totalValid && $totalValid%$this->perBatch == 0){ if(!empty($ids)){ $this->db->setQuery('DELETE FROM '.hikashop_table('product_related').' WHERE product_id IN ('.implode(',',$ids).') AND product_related_type='.$this->db->Quote($type)); $this->db->query(); $ids=array(); } if(!empty($id)){ $this->db->setQuery($insert.implode('),(',$values).')'); $this->db->query(); } $totalValid=0; $values=array(); } } } } if(!empty($ids)){ $this->db->setQuery('DELETE FROM '.hikashop_table('product_related').' WHERE product_id IN ('.implode(',',$ids).') AND product_related_type='.$this->db->Quote($type)); $this->db->query(); } if(count($values)){ $this->db->setQuery($insert.implode('),(',$values).')'); $this->db->query(); } }
function _insertRelated(&$products,$type='related'){ $values = array(); $totalValid=0; $insert = 'INSERT IGNORE INTO '.hikashop_table('product_related').' (`product_related_id`,`product_related_type`,`product_id`,`product_related_ordering`) VALUES ('; $ids=array(); foreach($products as $product){ if(!isset($product->$type) && empty($product->hikashop_update)){ //copy files from template if any if(@$product->product_type!='variant' && !empty($this->template->$type)){ $i = 0; foreach($this->template->$type as $id){ $value = array((int)$id,$this->db->Quote($type),$product->product_id,$i); $values[] = implode(',',$value); $totalValid++; if( $totalValid && $totalValid%$this->perBatch == 0){ $this->db->setQuery($insert.implode('),(',$values).')'); $this->db->query(); $totalValid=0; $values=array(); } $i++; } } }elseif(isset($product->$type)&&is_array($product->$type)){ $ids[] = (int)$product->product_id; $i = 0; foreach($product->$type as $k => $id){ if(!empty($id)){ $id = $this->_getRelated($id); $product->{$type}[$k] = $id; $value = array((int)$id,$this->db->Quote($type),$product->product_id,$i); $values[] = implode(',',$value); $totalValid++; } if( $totalValid && $totalValid%$this->perBatch == 0){ if(!empty($ids)){ $this->db->setQuery('DELETE FROM '.hikashop_table('product_related').' WHERE product_id IN ('.implode(',',$ids).') AND product_related_type='.$this->db->Quote($type)); $this->db->query(); $ids=array(); } if(!empty($id)){ $this->db->setQuery($insert.implode('),(',$values).')'); $this->db->query(); } $totalValid=0; $values=array(); } $i++; } } } if(!empty($ids)){ $this->db->setQuery('DELETE FROM '.hikashop_table('product_related').' WHERE product_id IN ('.implode(',',$ids).') AND product_related_type='.$this->db->Quote($type)); $this->db->query(); } if(count($values)){ $this->db->setQuery($insert.implode('),(',$values).')'); $this->db->query(); } }
in the file administrator/components/com_hikashop/helpers/import.php and that should allow the import to support it.
