Import will not import products from Virtuemart 3
10 years 10 months ago #219736 by urbanj
-- HikaShop version -- : HikaShop Business: 2.6.0
-- Joomla version -- : 3.4.5
-- Browser(s) name and version -- : chrome 46.0.2490.80
I have tried to import from Virtuemart 3 and it brings in the categories but fails to bring over any products. i get no errors of error reporting so i am at a loss as what to do.
Any help will be appreciated
10 years 10 months ago #220007 by Jerome
During the VirtueMart import, if you use the "VM2" import, there is a dropdown which ask for the language for the import.
VirtueMart store the product details into several tables and one of these tables is depending on a language code.
So if you do not import with the right language, the import will just have access to one part of the product details ; but without the other part, the import do not have enough data to create the product in HikaShop.
About VirtueMart 3 ; we know that the import is not perfect because the VM structure is changing a lot.
Our import has been designed for VM1 ; then we made a new import for VM2 and that last one could be compatible with VM3 ; but we had some bug feedback and we introduced some patches in the last versions of HikaShop.
That's why we don't officially support VM3 for the import but it should work (and it did work).
10 years 10 months ago #220010 by urbanj
Hi thanks for that. I have just noticed, the products have been transferred over but they have not been put into categories and have no images attached to them.
Does the above still apply?
10 years 9 months ago #224499 by urbanj
"About VirtueMart 3 ; we know that the import is not perfect because the VM structure is changing a lot.
That's why we don't officially support VM3 for the import but it should work (and it did work)."
OK so this is VM3 so the import:
Messed all the categories up
Put every product in the root directory and not in the categories
All images are blank.
Never imported prices
Can we give you the login details to take a look at this please. We bought HikaShop business on the understanding that we could import from VirtueMart
Time to create page: 0.154 seconds
