Export products with cirilic names encoding issue
10 years 9 months ago - 10 years 9 months ago #224868
by filiar
Export products with cirilic names encoding issue was created by filiar
-- Joomla version -- : 3.4.6
when trying to export products there is an encoding problem. The language is Bulgarian (cirilic). The encoding of the site and db connection is UTF-8.
Iliya
Iliya
Last edit: 10 years 9 months ago by filiar.
10 years 9 months ago #224873
Replied by nicolas on topic Export products with cirilic names encoding issue
The CSV displays just fine on my end:
take.ms/GqOlY
So the problem is the way you're opening your CSV.
Make sure that you select UTF8 in the CSV import system you're using to visualize it.
I'm using LibreOffice Calc (which is completely free) and it work great without doing anything.
take.ms/GqOlY
The following user(s) said Thank You: filiar
10 years 9 months ago - 10 years 9 months ago #224949
by filiar
Replied by filiar on topic Export products with cirilic names encoding issue
Thank you nicolas. It really is the encoding settings of the software tool that I am using. In my case excel.
For those who will meet simmilar issue, there is the solution:
Use the import function under "Data" tab where Excel allows us to specify the encoding. Select "from text" and choose your csv file then Select proper encoding ( in my case UTF-8 ).
Iliya
Iliya
Time to create page: 0.199 seconds
