After CSV import, product opening problem.
9 years 10 months ago #258915 by nykodesign
I have a problem. I'm doing import the CSV file, upload your products it is all right.
The UTF8 character set, it is ok. But frontend view, coming 404 errors, if I want look at the product details
Where to find the problem?
9 years 10 months ago #258916 by nicolas
We would need more information to be able to help :
- a copy of the CSV
- a link to the listing of the products
- a screenshot of the settings under the "products options" tab of your menu item
- a screenshot of the SEF settings under the Features tab of the HikaShop configuration
9 years 10 months ago #258998 by nicolas
You have this issue because the "alias" of your product is not filled and you have special characters (accents) in your product name, and you didn't turn on the "Unicode Aliases" setting in the Joomla configuration.
The following user(s) said Thank You: nykodesign
9 years 10 months ago #259049 by nykodesign
Thank you, so it's all right! :)
