- Thank you received: 2
Importing Products and Product Variants at the same time
8 years 8 months ago #288283
by jtquinto
Importing Products and Product Variants at the same time was created by jtquinto
-- HikaShop version -- : 3.3.0
-- Joomla version -- : 3.8.5
I'm trying to populate a shop catalog with some sample products and their corresponding variants thru a CSV file.
The results seem ok, at first; I imported 2 products with 2 and 3 variants, respectively, and 7 items have been created. When I check the Product List in the back-end, the 2 main items and 5 variants are listed and published, as expected.
However, the product variants do not show up in the front-end and are not accessible in the back-end (only the parent product page opens, and there is no Variants tab) until I actually add and save the Characteristics to the main product page.
After that, the Variants tab would show with the proper number of Imported variant items, but the list would show them having the selected default values in the Characteristics section of the main product page. ... but the variants would have the proper values saved when you open their detail page.
I've attached the sample CSV file I'm using:
Also...how to set the default Product Variant when importing from CSV?
I'm getting a "No Default Variant" warning message when the selected Characteristics default values are not in the imported Variants listings.
8 years 8 months ago #288289
Replied by nicolas on topic Importing Products and Product Variants at the same time
As you guessed, you're missing something in your CSV.
You need to set the default value in the cell of the characteristic for the main product in your CSV:
monosnap.com/file/9Wadhr1ccOmm2hDXAQ2WK06QaUjR2f
The following user(s) said Thank You: jtquinto
Time to create page: 0.042 seconds
