How are affiliate clicks recorded?
12 years 5 months ago #161285 by Sjaak
-- url of the page with the problem -- : artlantismedia.com
-- Joomla version -- : 2.5
I set up an affiliate program and have a few afiliate partners showing my banners on their website.
I also use an app that monitors traffic on my website (Extrawatch Pro). Using this app I see visitors coming from the partner websites. The app even mentions the affiliate Partner ID. So the banners work OK. They send visitors to my website.
BUT....
When I look in Hikashop/affiliates/Clicks I do not see clicks recorded.
So now I am puzzled: Is something going wrong here? Did I set set it up wrong? Are affiliate clicks recorded by Hikashop?
Can somebody explain?
Sjaak
12 years 5 months ago #161324 by nicolas
You should see the clicks there. We do see them on our end (on our website for example).
Maybe there is a bug ?
If you turn on the "error reporting" and "debug mode" options of the Joomla configuration and that you click on an affiliate link, to you get an error ?
12 years 5 months ago #161374 by Sjaak
Hello Nicolas,
I followed your advise. Debug mode 'ON'. Error reporting 'ON'. On the website of one affiliate partner I clicked a banner.
No error shown. My website opened OK. No Click was recorded by Hikashop. Extrawatch mentions a visitor (with my IPaddress) coming from the partners website mentioning their affiliate ID.
Do I need to look somewhere else for the error?
Sjaak
12 years 5 months ago #161391 by nicolas
Ok. I see only two possibilities in that case. Either the MySQL is failing or the partner_id in the URL is not for a valid partner (not activated, account deleted for that id)
Could you provide the MySQL queries traces at the bottom of that page that you see with the debug turned on ?
12 years 5 months ago #161478 by Sjaak
I do not get an SQLquery at the bottom of the page with debug on.
The Affiliate partner indeed appears to have more than one user accounts. So I checked: The affiliate ID is the same as the Hikashop customer ID. That is correct right?
The affiliate account is set to active.
I have set the most recent joomla user account 'enabled' and active in joomla. It's the one that fits the data as shown in the affiliate account.
Should the joomla user ID be the same as the hikashop customer ID?
Sjaak
12 years 5 months ago #161496 by nicolas
You should definitely get the queries at the bottom of the pages with the debug mode of the Joomla configuration on.
www.inmotionhosting.com/support/edu/joom...ettings/debug-system
If you don't, then this would indicate that your joomla template is coded to not display the debug data.
The fact that the joomla user id and the hikashop user id are different is normal, but the partner id and the hikashop user id should be the same.
How about to look at the clicks listing of the backend with the debug mode turned on ? Maybe the error is during the display of the listing and not during the saving of the click.
12 years 4 months ago - 12 years 4 months ago #162668 by Sjaak
I tried your last suggestion but that did not give me any new information. With debug mode on I neither get error messages.
Sjaak
Last edit: 12 years 4 months ago by Sjaak. Reason: correction of typos
12 years 4 months ago #162671 by nicolas
Ok. Then what if you temporarily change your frontend template to the default one of Joomla, make sure that the debug plugin of Joomla is activated and try again the procedure ? That way, you should get the queries debug at the bottom.
12 years 4 months ago #162868 by Sjaak
pfff, first I thought you meant the debug system in the joomla global configuration. Only after your last post I looked in my plugins and enabled the plugin.
Well it's on now and at the bottom of the page I see ' Joomla! debug console'. It has 4 sections. Session, Profile information, Memory usage and Database Queries.
I assume you need the last?
Sjaak
12 years 4 months ago #162900 by nicolas
Yes, I need the last one.
12 years 4 months ago - 12 years 4 months ago #162958 by Sjaak
I activated the debug plugin. Then I visited the webpage of one of my partners. I clicked my banner. Was redirected to my website. Guess what....no debug infromation at the botom of the page. I get debug information on all my pages except when I cilck an affiliate banner. Strange he?
In the backend I went to the affiliateclicks page of hkashop. At least there I could get some debug info. I don't know if that is what you need.
Thanks for helping me.
Sjaak
Copy/paste of debug info:
19 Queries Logged SELECT `data` FROM `jos_session` WHERE `session_id` = 'dpkuk0idb02b9fg062r19smij6' SELECT extension_id AS id, element AS "option", params, enabled FROM jos_extensions WHERE `type` = 'component' AND `element` = 'com_languages' SELECT folder AS type, element AS name, params FROM jos_extensions WHERE enabled >= 1 AND type ='plugin' AND state >= 0 AND access IN (1,1,2,3,4) ORDER BY ordering SELECT template, s.params FROM jos_template_styles as s LEFT JOIN jos_extensions as e ON e.type='template' AND e.element=s.template AND e.client_id=s.client_id WHERE s.client_id = 1 AND home = 1 ORDER BY home SELECT extension_id AS id, element AS "option", params, enabled FROM jos_extensions WHERE `type` = 'component' AND `element` = 'com_akeebasubs' SELECT config_value FROM jos_hikashop_config WHERE config_namekey = 'version' SELECT extension_id AS id, element AS "option", params, enabled FROM jos_extensions WHERE `type` = 'component' AND `element` = 'com_coalawebtraffic' SELECT extension_id AS id, element AS "option", params, enabled FROM jos_extensions WHERE `type` = 'component' AND `element` = 'com_hikashop' SELECT * FROM jos_hikashop_config SELECT a.*, b.user_email, b.user_currency_id FROM jos_hikashop_click AS a JOIN jos_hikashop_user AS b ON a.click_partner_id = b.user_id WHERE a.click_partner_paid=0 ORDER BY a.click_id desc LIMIT 0, 30 SELECT COUNT(*) FROM jos_hikashop_click AS a JOIN jos_hikashop_user AS b ON a.click_partner_id = b.user_id WHERE a.click_partner_paid=0 SELECT * FROM jos_hikamarket_config SELECT m.id, m.title, m.module, m.position, m.content, m.showtitle, m.params, mm.menuid FROM jos_modules AS m LEFT JOIN jos_modules_menu AS mm ON mm.moduleid = m.id LEFT JOIN jos_extensions AS e ON e.element = m.module AND e.client_id = m.client_id WHERE m.published = 1 AND e.enabled = 1 AND (m.publish_up = '0000-00-00 00:00:00' OR m.publish_up <= '2014-07-04 09:04:00') AND (m.publish_down = '0000-00-00 00:00:00' OR m.publish_down >= '2014-07-04 09:04:00') AND m.access IN (1,1,2,3,4) AND m.client_id = 1 AND (mm.menuid = 0 OR mm.menuid <= 0) ORDER BY m.position, m.ordering SELECT COUNT(*) FROM jos_messages WHERE state = 0 AND user_id_to = 62 SELECT COUNT(session_id) FROM jos_session WHERE guest = 0 AND client_id = 1 SELECT COUNT(session_id) FROM jos_session WHERE guest = 0 AND client_id = 0 SELECT a.*, SUM(b.home) AS home,b.language,l.image,l.sef,l.title_native FROM jos_menu_types AS a LEFT JOIN jos_menu AS b ON b.menutype = a.menutype AND b.home != 0 LEFT JOIN jos_languages AS l ON l.lang_code = language WHERE (b.client_id = 0 OR b.client_id IS NULL) GROUP BY a.id, a.menutype, a.description, a.title, b.menutype,b.language,l.image,l.sef,l.title_native SELECT m.id, m.title, m.alias, m.link, m.parent_id, m.img, e.element FROM jos_menu AS m LEFT JOIN jos_extensions AS e ON m.component_id = e.extension_id WHERE m.client_id = 1 AND e.enabled = 1 AND m.id > 1 ORDER BY m.lft UPDATE `jos_session` SET `data` = '__default|a:8:{s:15:\"session.counter\";i:29;s:19:\"session.timer.start\";i:1404464212;s:18:\"session.timer.last\";i:1404464636;s:17:\"session.timer.now\";i:1404464640;s:22:\"session.client.browser\";s:109:\"Mozilla/5.0 (Windows NT 6.1; WOW64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/35.0.1916.153 Safari/537.36\";s:8:\"registry\";O:9:\"JRegistry\":1:{s:7:\"\0*\0data\";O:8:\"stdClass\":5:{s:11:\"application\";O:8:\"stdClass\":1:{s:4:\"lang\";s:0:\"\";}s:11:\"com_plugins\";O:8:\"stdClass\":2:{s:7:\"plugins\";O:8:\"stdClass\":4:{s:6:\"filter\";O:8:\"stdClass\":4:{s:6:\"search\";s:5:\"debug\";s:6:\"access\";i:0;s:5:\"state\";s:0:\"\";s:6:\"folder\";s:0:\"\";}s:10:\"limitstart\";i:0;s:8:\"ordercol\";s:6:\"folder\";s:9:\"orderdirn\";s:3:\"asc\";}s:4:\"edit\";O:8:\"stdClass\":1:{s:6:\"plugin\";O:8:\"stdClass\":2:{s:2:\"id\";a:0:{}s:4:\"data\";N;}}}s:6:\"global\";O:8:\"stdClass\":1:{s:4:\"list\";O:8:\"stdClass\":1:{s:5:\" limit\";i:30;}}s:13:\"com_templates\";O:8:\"stdClass\":2:{s:6:\"styles\";O:8:\"stdClass\":1:{s:10:\"limitstart\";i:0;}s:4:\"edit\";O:8:\"stdClass\":1:{s:5:\"style\";O:8:\"stdClass\":2:{s:2:\"id\";a:0:{}s:4:\"data\";N;}}}s:12:\"com_hikashop\";O:8:\"stdClass\":1:{s:4:\"user\";O:8:\"stdClass\":1:{s:14:\"filter_partner\";i:1;}}}}s:4:\"user\";O:5:\"JUser\":25:{s:9:\"\0*\0isRoot\";b:1;s:2:\"id\";s:2:\"62\";s:4:\"name\";s:5:\"Sjaak\";s:8:\"username\";s:5:\"admin\";s:5:\"email\";s:26:\"contact@artlantismedia.com\";s:8:\"password\";s:65:\"28693969dedde7b677d699205c154ce1:tTA7evEnX1GNodIJH7Ge4ADrnkgUthpq\";s:14:\"password_clear\";s:0:\"\";s:8:\"usertype\";s:19:\"Super Administrator\";s:5:\"block\";s:1:\"0\";s:9:\"sendEmail\";s:1:\"1\";s:12:\"registerDate\";s:19:\"2009-07-28 22:04:58\";s:13:\"lastvisitDate\";s:19:\"2014-07-04 08:26:18\";s:10:\"activation\";s:0:\"\";s:6:\"params\";s:92:\"{\"admin_style\":\"\",\"admin_language\":\"\",\"language\":\"\",\"editor\":\"\",\"helpsite\":\"\",\"timezone\":\"\"}\";s:6:\"groups\";a:3:{i:1;s:1:\"1\";i:2;s:1:\"2\";i:8;s:1:\"8\";}s:5:\"guest\";i:0;s:13:\"lastResetTime\";s:19:\"0000-00-00 00:00:00\";s:10:\"resetCount\";s:1:\"0\";s:10:\"\0*\0_params\";O:9:\"JRegistry\":1:{s:7:\"\0*\0data\";O:8:\"stdClass\":6:{s:11:\"admin_style\";s:0:\"\";s:14:\"admin_language\";s:0:\"\";s:8:\"language\";s:0:\"\";s:6:\"editor\";s:0:\"\";s:8:\"helpsite\";s:0:\"\";s:8:\"timezone\";s:0:\"\";}}s:14:\"\0*\0_authGroups\";a:3:{i:0;i:1;i:2;i:2;i:4;i:8;}s:14:\"\0*\0_authLevels\";a:5:{i:0;i:1;i:1;i:1;i:2;i:2;i:3;i:3;i:4;i:4;}s:15:\"\0*\0_authActions\";N;s:12:\"\0*\0_errorMsg\";N;s:10:\"\0*\0_errors\";a:0:{}s:3:\"aid\";i:0;}s:13:\"session.token\";s:32:\"3d6861d2077a4818ca6b14b18338a13b\";}__wf|a:1:{s:13:\"session.token\";s:32:\"9f11a15723a2c33f9e0c539c1cd07a12\";}' , `time` = '1404464640' WHERE `session_id` = 'dpkuk0idb02b9fg062r19smij6' 15 Query Types Logged, Sorted by Occurrences. SELECT Tables: 4 × SELECT extension_id AS id, element AS "option", params, enabled FROM jos_extensions 2 × SELECT COUNT(session_id) FROM jos_session 1 × SELECT COUNT(*) FROM jos_messages 1 × SELECT m.id, m.title, m.module, m.position, m.content, m.showtitle, m.params, mm.menuid FROM jos_modules AS m LEFT JOIN jos_modules_menu AS mm ON mm.moduleid = m.id LEFT JOIN jos_extensions AS e ON e.element = m.module AND e.client_id = m.client_id 1 × SELECT a.*, SUM(b.home) AS home,b.language,l.image,l.sef,l.title_native FROM jos_menu_types AS a LEFT JOIN jos_menu AS b ON b.menutype = a.menutype AND b.home != 0 LEFT JOIN jos_languages AS l ON l.lang_code = language 1 × SELECT m.id, m.title, m.alias, m.link, m.parent_id, m.img, e.element FROM jos_menu AS m LEFT JOIN jos_extensions AS e ON m.component_id = e.extension_id 1 × SELECT * FROM jos_hikamarket_confi 1 × SELECT a.*, b.user_email, b.user_currency_id FROM jos_hikashop_click AS a JOIN jos_hikashop_user AS b ON a.click_partner_id = b.user_id 1 × SELECT template, s.params FROM jos_template_styles as s LEFT JOIN jos_extensions as e ON e.type='template' AND e.element=s.template AND e.client_id=s.client_id 1 × SELECT folder AS type, element AS name, params FROM jos_extensions 1 × SELECT config_value FROM jos_hikashop_config 1 × SELECT * FROM jos_hikashop_confi 1 × SELECT `data` FROM `jos_session` 1 × SELECT COUNT(*) FROM jos_hikashop_click AS a JOIN jos_hikashop_user AS b ON a.click_partner_id = b.user_id OTHER Tables: 1 × UPDATE `jos_session` SET `data` = '__default|a:8:{s:15:\"session.counter\";i:29;s:19:\"session.timer.start\";i:1404464212;s:18:\"session.timer.last\";i:1404464636;s:17:\"session.timer.now\";i:1404464640;s:22:\"session.client.browser\";s:109:\"Mozilla/5.0 (Windows NT 6.1; WOW64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/35.0.1916.153 Safari/537.36\";s:8:\"registry\";O:9:\"JRegistry\":1:{s:7:\"\0*\0data\";O:8:\"stdClass\":5:{s:11:\"application\";O:8:\"stdClass\":1:{s:4:\"lang\";s:0:\"\";}s:11:\"com_plugins\";O:8:\"stdClass\":2:{s:7:\"plugins\";O:8:\"stdClass\":4:{s:6:\"filter\";O:8:\"stdClass\":4:{s:6:\"search\";s:5:\"debug\";s:6:\"access\";i:0;s:5:\"state\";s:0:\"\";s:6:\"folder\";s:0:\"\";}s:10:\"limitstart\";i:0;s:8:\"ordercol\";s:6:\"folder\";s:9:\"orderdirn\";s:3:\"asc\";}s:4:\"edit\";O:8:\"stdClass\":1:{s:6:\"plugin\";O:8:\"stdClass\":2:{s:2:\"id\";a:0:{}s:4:\"data\";N;}}}s:6:\"global\";O:8:\"stdClass\":1:{s:4:\"list\";O:8:\"stdClass\":1:{s:5:\" limit\";i:30;}}s:13:\"com_templates\";O:8:\"stdClass\":2:{s:6:\"styles\";O:8:\"stdClass\":1:{s:10:\"limitstart\";i:0;}s:4:\"edit\";O:8:\"stdClass\":1:{s:5:\"style\";O:8:\"stdClass\":2:{s:2:\"id\";a:0:{}s:4:\"data\";N;}}}s:12:\"com_hikashop\";O:8:\"stdClass\":1:{s:4:\"user\";O:8:\"stdClass\":1:{s:14:\"filter_partner\";i:1;}}}}s:4:\"user\";O:5:\"JUser\":25:{s:9:\"\0*\0isRoot\";b:1;s:2:\"id\";s:2:\"62\";s:4:\"name\";s:5:\"Sjaak\";s:8:\"username\";s:5:\"admin\";s:5:\"email\";s:26:\"contact@artlantismedia.com\";s:8:\"password\";s:65:\"28693969dedde7b677d699205c154ce1:tTA7evEnX1GNodIJH7Ge4ADrnkgUthpq\";s:14:\"password_clear\";s:0:\"\";s:8:\"usertype\";s:19:\"Super Administrator\";s:5:\"block\";s:1:\"0\";s:9:\"sendEmail\";s:1:\"1\";s:12:\"registerDate\";s:19:\"2009-07-28 22:04:58\";s:13:\"lastvisitDate\";s:19:\"2014-07-04 08:26:18\";s:10:\"activation\";s:0:\"\";s:6:\"params\";s:92:\"{\"admin_style\":\"\",\"admin_language\":\"\",\"language\":\"\",\"editor\":\"\",\"helpsite\":\"\",\"timezone\":\"\"}\";s:6:\"groups\";a:3:{i:1;s:1:\"1\";i:2;s:1:\"2\";i:8;s:1:\"8\";}s:5:\"guest\";i:0;s:13:\"lastResetTime\";s:19:\"0000-00-00 00:00:00\";s:10:\"resetCount\";s:1:\"0\";s:10:\"\0*\0_params\";O:9:\"JRegistry\":1:{s:7:\"\0*\0data\";O:8:\"stdClass\":6:{s:11:\"admin_style\";s:0:\"\";s:14:\"admin_language\";s:0:\"\";s:8:\"language\";s:0:\"\";s:6:\"editor\";s:0:\"\";s:8:\"helpsite\";s:0:\"\";s:8:\"timezone\";s:0:\"\";}}s:14:\"\0*\0_authGroups\";a:3:{i:0;i:1;i:2;i:2;i:4;i:8;}s:14:\"\0*\0_authLevels\";a:5:{i:0;i:1;i:1;i:1;i:2;i:2;i:3;i:3;i:4;i:4;}s:15:\"\0*\0_authActions\";N;s:12:\"\0*\0_errorMsg\";N;s:10:\"\0*\0_errors\";a:0:{}s:3:\"aid\";i:0;}s:13:\"session.token\";s:32:\"3d6861d2077a4818ca6b14b18338a13b\";}__wf|a:1:{s:13:\"session.token\";s:32:\"9f11a15723a2c33f9e0c539c1cd07a12\";}' , `time` = '1404464640'
Last edit: 12 years 4 months ago by Xavier. Reason: Use of [code] tag
12 years 4 months ago - 12 years 4 months ago #163393 by Sjaak
I have some plans to expand the affiliate program. But first I need to have it working properly.
Any new insights on this one?
Sjaak
Last edit: 12 years 4 months ago by Sjaak. Reason: correcting typo
12 years 4 months ago #163783 by Sjaak
My problem still exists. Can someone please surprise me with an update on this one?
12 years 4 months ago #163810 by Jerome
The clicks are recorded by the system plugin "hikashopaffiliate".
In the trigger "onAfterRoute", the plugin read the parameter "partner_id" (or another parameter depending of the configuration of the hikashopaffiliate plugin, you can rename it if you want).
If the partner id value point to an existing partner, the plugin will continue his process and at the end of the function you can see that a "click" object is stored in the database.
If the click is not stored, it could be because the user is not found or the "user_partner_activated" is not set.
The best at this moment will be to add some debug data in the plugin in order to understand the process.
You might use the "$app->enqueueMessage('....');" in order to display information in the plugin and get some information about the process.
Hope it will help.
12 years 4 months ago #163845 by Sjaak
Sorry to say so but it doesn't help much.
Please tell me where to find the "onAfterRoute" trigger. Screenshot attached.
And I do not know how to use "$app->enqueueMessage('....');"
user is activated IserID is correct.
Best regards,
Sjaak
12 years 4 months ago #163850 by Jerome
It is in the source code of the plugin.
It requires some full debug in the plugin in order to understand why the plugin is not called and the click is not stored in the database.
Because, it is possible that something else in your website block the hikashop affiliate plugin to work correctly.
12 years 4 months ago #164021 by Sjaak
Well, apparantly the plugin does not work correctly. Since I do not know how to code I buy software so I don't have to code.
Some time passed since I posted my question and now it seems something has to be done in the sourcecode.... :dry: .....mmmh
How can this be solved?
Best regards
Sjaak
12 years 4 months ago #164027 by Jerome
Well, some credentials will be required if you want us to make some debug in your website.
A backend access to check your configuration, see the affiliates, their clicks and see the other system plugins in place in your website.
A ftp access to edit the hikashop affiliate plugin directly and add some debug data into.
You can send such private information using private message.
12 years 2 months ago #170740 by Sjaak
Hi Jerome,
I sent you a PM.
Thanks in advance
Sjaak
12 years 2 months ago #170764 by Jerome
Thanks for the access but you send me only the backend one, not the FTP.
Time to create page: 0.132 seconds
