- Thank you received: 1
Multi-Teired Affiliate System?
12 years 1 month ago #174100
by jerrico
Multi-Teired Affiliate System? was created by jerrico
-- HikaShop version -- : HikaShop Business 2.3.3
-- Joomla version -- : 3.3
Good day,
I'm needing to add a two-tiered affiliate system, where if someone comes to the site via an affiliate link, and becomes an affiliate, the first affiliate gets a (smaller) flat-fee bonus for the sales generated from the child affiliate.
I've searched, but the most recent mention of this was over a year ago, so I'm hoping it has been added since then?
Thank you!
Good day,
Thank you!
12 years 1 month ago #174102
by Jerome
Replied by Jerome on topic Multi-Teired Affiliate System?
The HikaShop affiliate plugin does not provide such kind of feature.
But HikaShop have some third party extensions that you will be able to find in our documentation (under "integration") or in the joomla extension directory.
I see for example "Affiliate Tracker by Joomla That" but I can't tell you if it will feet to your requirements.
11 years 4 months ago #204802
by Customizedvapor
Replied by Customizedvapor on topic Multi-Teired Affiliate System?
Modes that even integrate into Hikashop?
11 years 4 months ago #204803
by Customizedvapor
Does that* only multi tiered third party I could find that says easy Hikashop integration is only joomla 2.5 compatible.
11 years 4 months ago #204926
Replied by nicolas on topic Multi-Teired Affiliate System?
I would recommend to contact them.
On our end, having a multi tiered affiliate system would require redeveloping that feature from 0 so it would be a lot of work and we don't plan on doing it in the short term.
Time to create page: 0.100 seconds
