Related Products broke
15 years 8 months ago #10160 by mohairbears
Hi Again, I appear to have broken 'Related Products' the code is showing instead of the wording? I have tried unistalling and creating a new module but this still fails. please see attached, this only effects 'Related Products'
15 years 8 months ago #10165 by jasonm
Replied by jasonm on topic Re: Related Products broke
It appers you have modified the language file and have something out of place? Make sure any changes you make are in the override section.
15 years 8 months ago #10166 by mohairbears
Hi, I have not modified any files since it was working ok? have checked the language file and it looks ok, even used the todate one from your site and this has not worked. I have been installing some modules/extentions and unistalling them as they did not work correctly so this may have caused the problem, anywhere else I could look for the issue?
thanks
15 years 8 months ago #10178 by nicolas
Replied by nicolas on topic Re: Related Products broke
It indeed seems that you have a problem with your translation file. Please try to retrieve a new version from our servers via the interface in the config under the tab languages.
15 years 8 months ago #10197 by mohairbears
Hi, still cannot solve this? the language file looks ok, downloaded current version, none of the links work in related product either, not sure if this might identify the problem?
thanks
15 years 8 months ago #10199 by mohairbears
Made some progress with this but still got a problem, it does as first show on the image below as you will see if you follow this link
www.mohairbearmakingsupplies.co.uk/index...ut=listing&Itemid=52
then select one of the related products, you will now see it's ok? select the stuffing tool again and you will see the page where you first landed and was screwed up is now ok?
hope this helps.
thanks
15 years 8 months ago #10200 by nicolas
It seems that you edited the file listing_price of the view product and changed the way the price is displayed. It might come from that. Could you check the code there ?
If you reverse the customization of the view, does it work ?
15 years 8 months ago #10202 by mohairbears
Not changed anything there that I am aware of? price changes are coming from the language file in the override I have tried removing the comments there but it still does not work and has worked ok since the comments were put in the override?
15 years 8 months ago #10204 by nicolas
Could you check in the menu Display->Views if the file listing_price of the view has been customized, just in case ?
15 years 8 months ago #10205 by mohairbears
Deleted the changes made 3 weeks ago, that has not made it work correctly?
15 years 8 months ago #10206 by nicolas
I see that you have your related products module as a normal module of your template. Instead, could you unpublish it and add it to the option "modules under the product page" ?
15 years 8 months ago #10213 by mohairbears
It was already in the modules under prouct page and published. The ordering field in parameters is set to ordering is that correct?
15 years 8 months ago #10226 by mohairbears
it's ok I have sorted it.
thanks
15 years 8 months ago #10228 by nicolas
What was it ?
15 years 8 months ago #10230 by mohairbears
It was the 'modules to display under the main area' that was the problem, published the one under the product page and that one works ok but the other still does not work, still not to worry as this one works.
thanks
Time to create page: 0.128 seconds
