How to integrate third party tracking system
15 years 7 months ago #11877 by nicolas
Concerning the authorize.net error, could you try to activate the debug mode ? Then, do an order and look at the payment log file in FTP ?
That should provide more info on the problem.
For the notice: that a problem in the performance_based plugin. The question is, what do you have on the line 15 of that file ?
For the JUser error: Could you do screenshot ?
15 years 7 months ago - 15 years 7 months ago #12059 by bthayer
I'll get back to this one if it happens again. I did have the shopping cart in debug mode but I can't see any payment logs?.
<?php // no direct access defined( '_JEXEC' ) or die( 'Restricted access' ); // Import library dependencies jimport('joomla.plugin.plugin'); class plgHikashopNotify_performance_based extends JPlugin{ function plgHikashopNotify_performance_based(){ parent::__construct(); // load plugin parameters $this->_plugin = JPluginHelper::getPlugin( 'hikashop', 'notify_perfomance_based' ); $this->_params = new JParameter( $this->_plugin->params ); } function onAfterOrderUpdate(&$order,&$send_email){ $config=&hikashop::config(); $confirmed = $config->get('order_confirmed_status'); //if order status is not updated skip if(!isset($order->order_status)) return true; $class = hikashop::get('class.order'); $dbOrder = $class->get($order->order_id);
Last edit: 15 years 7 months ago by bthayer.
15 years 7 months ago #12069 by nicolas
These problems were caused by your performance based plugin which didn't had a correct constructor. The modification I made to it solved both problems.
15 years 7 months ago - 15 years 7 months ago #12153 by bthayer
Where is th3e modifications again? I don't see them or my original code above anymore.
Is it OK to use https:// in the curl_init() code?
15 years 7 months ago #12169 by nicolas
15 years 7 months ago - 15 years 7 months ago #12196 by bthayer
Found out that another cookie called roia_cookie was needed. I added this code to the attached plugin:
$roia=""; if(isset($_COOKIE['roia_cookie'])) $roia = $_COOKIE['roia_cookie']; else return true;
and added this to my thank-you page (after making my thank-you page my new return page):
<script type="text/javascript">document.write('<input type="hidden" name="roia" value="' + roia_cookie + '">')</script>
(I also learned that my editor strips off script tags :( )
This script is in one of my modules to create the cookie:
<!--ROIA #1205--> <script type="text/javascript">/*<![CDATA[*/ (function(D,u,q,i,p,c){if(D.cookie){q=D.cookie.split(';');for(i=0;i<q.length;++i) {p=q[i].split('=',2);if(/^\s*roia1205$/.test(p[0])){c=p[1];break;}}} if(c){u+=(u.indexOf('?')==-1?'?':';')+'_roia_js_cookie='+c;} D.write('<'+'script type="text/javascript" src="http'+(/^https:/.test(D.URL)?'s':'')+'://'+u+'"></'+'script>'); })(document,'net.performance-based.com/j/1205'); /*]]>*/</script> <!--/ROIA #1205-->
My logic must be flawed. i don't think the cookies are persisting through the authorize transaction to the thank you page.
I am trying to figure this out but my skills are nada. :unsure:
P.S.
This error is on all my pages at the top. Will it go away when this is all done?
Notice: Undefined index: QUERY_STRING in /hermes/bosweb25b/b706/ipg.heatmisersavescom/libraries/joomla/environment/uri.php on line 161
15 years 7 months ago #12209 by nicolas
The way you're doing it, that will add the cookie to the browser of the user but not in the curl request. You need to do something like this:
coderscult.com/php/php-curl/2008/05/20/p...url-cookies-example/
For the query string error, the error is a joomla error so I don't know from where it's coming. What you could do is add a @ in front of the $_SERVER so that notice doesn't display.
15 years 7 months ago #12327 by bthayer
1) For the error above - Under Global configuration I had the error reporting level set to maximum. I switched it to none and that stopped the error mentioned above.
2) I am giving up on the notify_performance_based.php plugin.
3a) I am testing my shopping cart in IE and noticed these errors after the Authorize.net transaction completes:
Warning:
Cannot modify header information - headers already sent by (output started at /hermes/bosweb25b/b706/ipg.heatmisersavescom/components/com_hikashop/controllers/checkout.php:901) in /hermes/bosweb25b/b706/ipg.heatmisersavescom/templates/cloudbase/libs/ja.template.helper.php on line 130
3b) Also the page does not redirect back to my site.
4) IE and Firefox - Shopping cart requires 2 clicks to check out.
5) I noticed that the my-orders page requires a login. I'm sure this is expected behavior but really, why? There is already a cookie set and email on file. I know this because when I click on the register link the email field is already filled in.
6) One thing I find annoying while debugging is the next button disappears when i return and want to run another transaction.
7) Your cool!
8) Wouldn't it also be cool to have a debug plugin that creates test transactions & a reset plugin?
15 years 7 months ago #12348 by nicolas
3. Is the order confirmed ? Do you get a "success" email ?
What do you see on the page ?
4. Please turn on the option "Auto submit shipping and payment methods selection"
5. The email is prefilled by your browser automatically as it recognize the field. There is no cookie set by hikashop and no means to know who is accessing the order so hikashop is not able to know which orders should be displayed for who.
6. The next button is removed because you have to reregister first since hikashop considers you as a new customer again in "no registration" mode.
8. How do you see that ?
15 years 7 months ago #12453 by bthayer
yes
Done. Just need to test it again
Configure it with a test user name, address, phone, uname and test password and test products. The when you call the plugin it pre-fills the registration form and fills in and opens the shopping cart. The reset plugin changes all orders from that test person to canceled then deletes the orders and the user. It would save a lot of typing.
15 years 7 months ago - 15 years 7 months ago #12455 by bthayer
I just got word from my affiliate manager. He is making progress of the tracking pixel but needs the variables from this code.
<img src=" net.performance-based.com/l/259?id= <?php print $order_number;?>;amount=<?php print $dbOrder->order_full_price-($vat+$dbOrder->order_shipping_price+$dbOrder->order_discount_price);" alt="" width="1" height="1" border="0" style="width:1px;height:1px;border:0"
to be kept alive on the Thank you page.
The above code can be viewed in full in the topic history. It is not displaying here in full for some reason.
Last edit: 15 years 7 months ago by nicolas.
15 years 7 months ago #12497 by nicolas
Could you change the line:
if(!is_bool($data) && !empty($data)){
if(is_string($data) && !empty($data)){
in the file components/com_hikashop/controllers/checkout.php
That should help for 3 a and b.
Thanks for the suggestion for the testing plugins/modules we'll see if and when we cam come up with something.
If you're adding the performance-based image in the thank you page of the authorize.net plugin, then you should be able to use the information in the $_GET variable to get the price and the order number:
$order_number = hikashop::encode($dbOrder);
15 years 7 months ago #12512 by bthayer
Do you mean the page entered in the Return URL field of the Authorize plugin?
15 years 7 months ago - 15 years 7 months ago #12530 by nicolas
I mean the file plugins/hikashoppayment/authorize_thankyou.php
15 years 7 months ago - 15 years 7 months ago #12650 by bthayer
Here's the file edited with the image tag.
<?php /** * @package HikaShop for Joomla! * @version 1.4.8 * @author hikashop.com * @copyright (C) 2010 HIKARI SOFTWARE. All rights reserved. * @license GNU/GPLv3 http://www.gnu.org/licenses/gpl-3.0.html */ defined('_JEXEC') or die('Restricted access'); //added for performance-based tracking image $plgOrder=$_GET['dbOrder'] $dbOrder = hikashop::encode($plgOrder); //closing tag <div class="hikashop_authorize_thankyou" id="hikashop_authorize_thankyou"> <img src="https://net.performance-based.com/l/259?id=<?php print $dbOrder->order_number;?>;amount=<?php print $dbOrder->order_full_price-($vat+$dbOrder->order_shipping_price+$dbOrder->order_discount_price);?>" alt="" width="1" height="1" border="0" style="width:1px;height:1px;border:0" /> <span id="hikashop_authorize_thankyou_message" class="hikashop_authorize_thankyou_message"> <?php echo JText::_('THANK_YOU_FOR_PURCHASE'); if(!empty($return_url)){ echo '<br/><a href="'.$return_url.'">'.JText::_('GO_BACK_TO_SHOP').'</a>'; }?> </span> </div> <?php if(!empty($return_url)){ $doc =& JFactory::getDocument(); $doc->addScriptDeclaration("window.addEvent('domready', function() {window.location='". $return_url."'});"); }
For some reason the code does not view but you can see it in the thread history.
The error says:
Parse error: syntax error, unexpected T_VARIABLE in /hermes/bosweb25b/b706/ipg.heatmisersavescom/plugins/hikashoppayment/authorize_thankyou.php on line 13
Are we getting closer?
15 years 7 months ago #12663 by nicolas
Instead of:
$plgOrder=$_GET
you should have:
$orderClass = hikashop::get('class.order');
$dbOrder = $orderClass->get((int)@$vars);
$products = $orderClass->loadProducts($dbOrder);
$vat = 0 ;
foreach($products as $product){
$vat+=$product->order_product_quantity*$product->order_product_tax;
15 years 7 months ago - 15 years 7 months ago #12810 by bthayer
Thank you,
I think we're almost there. My test run returned a conversion message from performance-based
This is a conversion notification from [HeatMiserSaves.com].
A conversion has been made by a visitor referred by publisher 104515.
Conversion information:
ID#: 629145938
Type: sale
Amount: $297.00
I just need to clean up some strange errors & we'll be there! (fingers crossed :side: )
This page appears for a second after the credit card goes through but before the thank you page is displayed. I had to be quick to get the Alt-PrtScr.
image missing http://www.hikashop.com/media/kunena/attachments/legacy/images/plugin_error.png
15 years 7 months ago #12828 by nicolas
You need to change the line:
foreach($dbOrder->products as $product){
15 years 7 months ago #12875 by bthayer
message from Warren at performance-based; "yeah nicolas"
He also said, "just noticed that the OrderID that hikapshop assigns is not coming through"
Mechanically things look like they are working but now I need to fix this error:
Warning
: Cannot modify header information - headers already sent by (out started at <path>/ipg.heatmisersaves.com/components/com_hikashop/controllers/checkout.php:901) in <path>/ipg.heatmisersaves.com/templates/cloudbase/libs/ja.template.helper.php on line 130.
15 years 7 months ago #12887 by nicolas
In your code you have:
but you don't have any code to generate it... You should replace it by:
print hikashop::encode($dbOrder);
For the warning, you can just edit the file templates/cloudbase/libs/ja.template.helper.php and add a @ at the beginning to hide the message.
Time to create page: 0.289 seconds
