- Thank you received: 2
Upload products with display and thumb images
15 years 8 months ago #10359
by momentis
Upload products with display and thumb images was created by momentis
I am going to processing thousands of images locally, for upload to my shop to create products. During the batch file I am developing, I can generate the display image and thumbnail image locally. Is there a way, during the upload process, to use a pre-made thumbnail image, without HikaShop generating one? If so, what field do I use in my csv to indicate this?
15 years 8 months ago #10360
by momentis
Replied by momentis on topic Re: Upload products with display and thumb images
...or does the system generate the thumbail dynamically on the front-end?
15 years 8 months ago #10361
Replied by nicolas on topic Re: Upload products with display and thumb images
If you don't have thumbnails, the thumbnails are indeed generated automatically by hikashop when it needs to display them.
15 years 8 months ago #10362
by momentis
But if I do generate them, is there a way to place these during an import?
15 years 8 months ago #10363
You can upload your main images in the folder media/com_hikashop/upload and the corresponding thumbnails in the folder media/com_hikashop/upload/thumbnail
Please make sure that they have the same name. You just need to specify the image name in the CSV and hikashop will be able to link that the the images/thumbnails automatically.
15 years 8 months ago #10364
by momentis
PERFECT!!! As usual, your product is amazing!
