Cart module alignment issue
15 years 8 months ago #10728
by Sub-R
Cart module alignment issue was created by Sub-R
I am having a problem with the prices in the cart module being cut off. I attached a picture showing the problem. The cart title and the headings are correct, but everything below that is shifted to the right. I have been going through the code for a couple hours and can't figure out where the problem is. Any suggestions?
15 years 8 months ago #10736
Replied by nicolas on topic Re: Cart module alignment issue
You should be able to fix that with just some CSS. I can't give you more precise directions without a link to that page.
15 years 8 months ago #10769
by Sub-R
Replied by Sub-R on topic Re: Cart module alignment issue
Hello Nicolas. The site is at
subversiverobot.cloudaccess.net/
15 years 8 months ago #10776
I tested on IE 7, IE 8, Firefox and Chrome and didn't had the module cut on the right on your website.
15 years 7 months ago #11509
by Sub-R
I checked the sit in Safari and IE and the module looks fine. But I am still having the problem in Firefox. I checked on three different computers (2 Macs and a PC) all running the latest version. Could you point me to the code that I would need to change in order to narrow the width of the module to prevent this from happening on a customers computer.
15 years 7 months ago #11510
The problem comes from the CSS code below in the file
subversiverobot.cloudaccess.net/template...ken/css/template.css
of your template :
.moduletable td, .moduletable_menu td {
padding: 3px 25px 0 15px;
If you change the 25px padding to somthing like 10px, it doesn't happen.
15 years 7 months ago #11513
by Sub-R
Thank you once again Nicolas. That was perfect.
