Building a menu system
15 years 7 months ago #11648 by pproject
I try to set up Hikashop business version for the following terms.
product1 (categories: girls, size1,size2,size4,)
product2 (categories: girls, size2, size3)
product3 (categories: boys, size1, size4)
product4 (categories: boys, size1, size2, size3)
Now I can list the products, selecting:(girls, subcategory size1) or (boys, subcategory size4)
but in these case, I have to set different subcategories for sizeX ( one for boys, one for girls)
I'd like to use only one category for sizeX (not many subcategories) and listing products:
menu item: girls (coming up all girls) submenu size1 (coming up all size1 which belongs to girls)
menu item: boys (coming up all boys) submenu size3 (coming up all size3 which belongs to boys)
Any chance to do that?
pproject
15 years 7 months ago #11652 by nicolas
Replied by nicolas on topic Re: Building a menu system
That's not possible with the binary tree structure that we use for categories (the same as joomla 1.6 categories structure). One category can only have one parent.
15 years 7 months ago #11657 by pproject
Replied by pproject on topic Re: Building a menu system
Thanks your quick reply.
Just thinking about further....
Other way, if I use multilevel searcing for listing products instead of menu system. I mean few dropdown selections which narrow
the listing step by step.
Can the built in category and product searching plugins assist for that, because I can't see any parameter set up in that plugins?
15 years 7 months ago #11661 by nicolas
There is no parameters for that in the search plugin. What you can do however is have several category listing modules. One for gender, one for size. then, if you have the gender categories under the size category and vice versa and that you add both possibilities in your products, you would be able to have the first level of categories as modules and then, when clicking on one category in the modules, you would get the listing of the sub categories and then the products in them after clicking on the sub category.
15 years 7 months ago #11662 by pproject
Yes, I did it that way, what you advise. Just I am dreaming about simplifying the category management...:)
An other question.
I have created a characteristic which contains all sizes and the same subcategory structure.
For given product linked the size categories where the product is available and put to enable the same sizes in characteristic.
That is working fine, just want improve the listing further by the available quantity of version(size). Listing the products
in given size first in order quantity. I mean given size of product higher quantity first,..... zero quantity last.
Just not able to configure the modul with parameters of versions.
15 years 7 months ago #11666 by nicolas
In HikaShop, you have an option to change the ordering of values: either by alphabetic order, or by value id. There is no option to do that based on the available quantity... That would only work for products with one characteristic so it's not really possible to have such option when you handle several characteristics for products.
