layout problems
i open the product page and the products are there in a div layout. all good so far but then what happens next is problematic. when i open a certain product it opens bellow the list instead of loading in a new and empty screen. same for the checkout and login check. they just append below. i would like it all to appear in a new and clean screen. this might be trivial but you can tar and feather me and i still can't figure it out
If you give a link to your website we would be able to give you more precise directions as to what to do.
image missing http://www.hikashop.com/media/kunena/attachments/legacy/images/hika-20110327.png
i still want that section to appear after the users login, just not before
