Mini cart module modification
15 years 7 months ago #12498 by webarts
hello,
i use the following template demo.gavick.com/joomla15/nov2010/index.php
there is a module position with name "cart" on this template but it can only be used with K2 and VM.
i use the latest version o essential version, when i use the module position for the hikashop mini cart it doesnt work properly.
here is the code in the template that i have to change
<?php if($this->countModules('cart')) : ?> <div id="gk-cart-btn"> <h2><?php echo JText::_('GK_SHOP_CART'); ?></h2> <div id="gk-items">[ <strong>...</strong> ] <?php echo JText::_('GK_ITEMS'); ?></div> <a href="index.php?page=checkout.index&amp;option=com_virtuemart&amp;Itemid=178&amp;redirected=1&amp;Itemid=9999" class="button"><?php echo JText::_('GK_GO_TO_CHECKOUT'); ?></a> </div> <div id="gk-cart"> <jdoc:include type="modules" name="cart" style="none" /> </div> <?php endif; ?>
what i have to do have in that position with the same style the Hikashop mini cart module?
i am trying to do something like the code below this but i cant get the virable for the hikashop items
<?php if($this->countModules('cart')) : ?> <div id="gk-cart-btn"> <h2><?php echo JText::_('GK_SHOP_CART'); ?></h2> <div id="gk-items">[ <strong>...</strong> ] <?php echo JText::sprintf('TOTAL_IN_CART_X'); ?></div> <a href="index.php?option=com_hikashop&ctrl=checkout&Itemid=180" class="button"><?php echo JText::_('GK_GO_TO_CHECKOUT'); ?></a> </div> <div id="gk-cart"> <jdoc:include type="modules" name="cart" style="none" /> </div> <?php endif; ?>
thank you
15 years 7 months ago #12500 by nicolas
What code do you have for VM for the <strong>...</strong> (the number of items) ?
In HikaShop, the number of items is calculated during the display of the module.
What I would do is just keep the code below in your template:
<div id="gk-cart">
</div>
and then modify the HTML code of the file cart of the view product in order to look like the VM one of that template.
15 years 7 months ago #12505 by webarts
i try that but it doesnt works propably is a template issue.
in the code for numbers of items is " echo JText::_('GK_ITEMS'); " i try to replace it with " JText::sprintf('TOTAL_IN_CART_X')" , but no luck.
15 years 7 months ago #12507 by nicolas
Of course. The number of items is calculated during the display of the module.
JText::sprintf('TOTAL_IN_CART_X') just displays a translation string. If you don't feed the number of items variable to it, it won't work and for that you have to load the whole cart and process it. That's why I said that the other solution should be easier.
15 years 7 months ago #12509 by webarts
but unfortunetly is not working the easy solution, it has to work, its template issue obviously.
i will try to find out was going on .
thank you nicolas..
you can post the difficult solution if its easy for you :)
15 years 7 months ago #12516 by nicolas
Without the template on our end, we can't test anything so we can't provide any precise solution but just give guidelines.
15 years 7 months ago #13313 by jameswadsworth
I don't want to hijack a discussion but my question is pertinent I believe to the current issue. I am creating a new template to use with hikashop. I have a bar at the top of the page where I would like to simply indicate the number of items the user has in their cart (among other information). I'd like to avoid using a module, and just insert a script into to index.php file of the template. Could you suggest how best to access this data if possible?
15 years 7 months ago #13328 by nicolas
You can do like that:
$class = hikashop::get('class.cart');
$rows = $class->get();
$qty = 0;
foreach($rows as $k => $row){
$qty += $row->cart_product_quantity;
echo $qty;
15 years 7 months ago #13351 by jameswadsworth
Thanks Nicolas for the solution. Just made a small change to avoid error msg when $rows is empty
$class = dacshop::get('class.cart');
$qty = 0;
if(!empty($rows)){
14 years 9 months ago #36142 by frama
I would like to have these three things:
# of items
Total ammount
Checkout Button
E.g.
Items: 1
Total: $15
Checkout
I am trying hard from minicart but i cant get it. Is this possible weather from minicart or from custom code on template index.php?
thanks
14 years 9 months ago #36184 by nicolas
The mini cart already displays the number of items and the total.
That that be activated by turning on the "mini cart" option of the hikashop cart module.
For a link to the checkout, you can easily add it in the file "cart" of the view "product" via the menu Display->Views with some HTML like that:
<a href="URL_OF_YOUR_CHECKOUT">Checkout</a>
14 years 9 months ago #36297 by frama
i did used the minicart, but when i add a product, it shows me full cart. when i navigate away from this product than i see only total ammount.
seems kind of bug!!!
14 years 9 months ago #36332 by nicolas
It shows you the full cart ?
Maybe you have some kind of caching issue ?
Could you make sure that the cache in the joomla configuration and in the joomla system cache plugin are both turned off.
Then,if that still doesn't change anything, could you give the URL of your page so that we can see that?
14 years 9 months ago #36351 by frama
www.gotech.al/test this is the url. i can give you administrator access if you want.
(in the left you have the shop categories in order to add products to the cart. top-right is the cart)
14 years 9 months ago #36399 by nicolas
Could you do a screenshot of your cart module's hikashop options screen ?
14 years 9 months ago #36422 by frama
have i attached correctly??
14 years 9 months ago #36424 by frama
this is the screen after i navigate away
14 years 9 months ago #36456 by nicolas
No, I'm talking about a screenshot of the options of the cart module, not the front end of your shop.
14 years 9 months ago #36480 by frama
i am talking about different behaviors for same settings!
14 years 9 months ago #36483 by frama
i found out something that may help. When i click add to cart, i see the pop up asking pay now or turn to the shop. when i say pay now, the page is going to different url and during this process the page is refreshed and minicart is displayed correctly. when i say turn to the shop page is not refreshed and i see big cart.
