Mini cart module modification
14 years 8 months ago #36537 by nicolas
That would indicate that you have several instances of the hikashop cart module.
Go in your joomla modules manager and look for the cart modules. Make sure that you have only one instance (delete the others) and make sure that the one left has the mini cart activated.
14 years 8 months ago #36614 by frama
that's right! i had another regular cart module enabled. Thank you!
12 years 11 months ago - 12 years 11 months ago #129718 by Lexnia
Hi, I am trying to display the minicart at the top of the page within the header div by including the following within the header div on the index.php file, but it's not working:
$class = hikashop::get('class.cart');
$rows = $class->get();
$qty = 0;
foreach($rows as $k => $row){
$qty += $row->cart_product_quantity;
echo $qty;
Do I have to include a php echo value before it? Please help?
Last edit: 12 years 11 months ago by Lexnia.
12 years 11 months ago #129802 by Xavier
First of all, you have to enable the Joomla debug mode, and set the error reporting to "maximum" in order to see the returned errors. Then we already have a module "cart" and in it's options you can set that you want to use it as a mini cart.
So you have to add a module position in your template file to display that module.
Else the code seems to be correct, do you have a cart for the current session ? Some articles in it ?
11 years 10 months ago #182458 by PigeonTech
I'm running Hikashop v2.2.0 on Joomla 3.3.6. Site url is diywetroom.pigeontech.co.uk
I'm using a chunk of code taken from this thread to display the number of cart items in a div
<?php $class = hikashop::get('class.cart'); $rows = $class->get(); $qty = 0; if(!empty($rows)){ foreach($rows as $k =>$row){ $qty += $row->cart_product_quantity; } } echo $qty; ?>
I'm using sourcerer so I can put the code direct into a Joomla module. Everything word fine until I think the browser cache cleared and now the hikashop class fails to be called giving error:
Fatal error: Class 'hikashop' not found in /home/dwrftp/diywetroom.pigeontech.co.uk/tests/cart_items.php on line 3
line 3 on my code is: $class = hikashop::get('class.cart');
Any ideas? I wondered if it might be the order in which the class is called?
11 years 10 months ago #182521 by nicolas
If you're running that code on a place where HikaShop is not (yet) loaded, you'll get that error as that code requires HikaShop's main helper to be loaded.
You can load it manually by simply adding a line like this before:
<?php require('/path/to/the/root/of/your/website/administrator/components/com_hikashop/helpers/helper.php'); ?>
Of course, /path/to/the/root/of/your/website is to be changed by the path to the root folder of your website.
11 years 10 months ago #182553 by PigeonTech
Thanks,
But now I get a different error when I access the store:
Fatal error: Cannot redeclare hikashop_getDate() (previously declared in /home/dwrftp/diywetroom.pigeontech.co.uk/administrator/components/com_hikashop/helpers/helper.php:65) in /home/dwrftp/diywetroom.pigeontech.co.uk/administrator/components/com_hikashop/helpers/helper.php on line 83
Guessing I need to disable a line of code but not sure which.
11 years 10 months ago #182556 by PigeonTech
Tried using require_once but get the following error:
Parse error: syntax error, unexpected ''); ' (T_CONSTANT_ENCAPSED_STRING) in /home/dwrftp/diywetroom.pigeontech.co.uk/tests/cart_items.php on line 5
11 years 10 months ago #182557 by PigeonTech
Hold The Phone! B)
using require_once worked. Just needed to refresh cache.
Many Thanks for your help.
11 years 10 months ago #182577 by Jerome
Right ; "require_once" is quite better to avoid double inclusion of the file :)
The following user(s) said Thank You: PigeonTech
8 years 1 month ago - 8 years 1 month ago #297668 by raskal
Hi, i m a little noob... where i have to put this code in i want to show numer item in cart?
$class = dacshop::get('class.cart'); $rows = $class->get(); $qty = 0; if(!empty($rows)){ foreach($rows as $k => $row){ $qty += $row->cart_product_quantity; } }
Thank You.
Last edit: 8 years 1 month ago by Jerome. Reason: [code] tag is nice
8 years 1 month ago #297675 by nicolas
There is no need for any code change anymore.
Just turn off the display options you don't want in the settings of the cart module via the Joomla modules manager and you'll be able to get only the quantity.
Time to create page: 0.191 seconds
