Listing of products
15 years 7 months ago #13336
by Nyx
Listing of products was created by Nyx
How i can add to product listing number of product to view pre screen or go to next for example 20 next products. It works in listing of categories but not in products. Even if i pick one category a product of that category are shown...no oportunity to list them is availibe...i was looking for it for hours...but no succes. I attachd picture of listin fields which i ment. Sry for my Englis:) thx for reply
image missing http://www.hikashop.com/media/kunena/attachments/legacy/images/listing.png
15 years 7 months ago #13371
Replied by nicolas on topic Re: Listing of products
You need to go in Display->Content modules, edit your products listing modules and turn off the "random" option.
15 years 7 months ago #13396
by Nyx
Replied by Nyx on topic Re: Listing of products but 1 problem left
Oo great
thx now i have only one problem. When i go to checkout..no shiping methods are displayed..neither error meesages that they cant be found. I created manualy shiping methods. They are related to zone Slovakia(type=country) and customer is loged and his adress is from Slovakia. I even tried to make Slovakia zones of all types related to shiping methods...but didnt worked. How can i fix this. Really thx for your help...i was desperate. i was siting whole day in front of that:D
15 years 7 months ago #13443
Replied by nicolas on topic Re: Listing of products but 1 problem left
Did you set a weight in your products ?
Here is a FAQ you should look at:
www.hikashop.com/en/support/documentatio...plugins-listing.html
15 years 6 months ago #13473
by Nyx
Replied by Nyx on topic List of categories
I am just wondering if i missed something...but i try to ask if..that list of categories in HikaShop is without of modifing source php code.If yes...where is it:) thx image missing http://www.hikashop.com/media/kunena/attachments/legacy/images/Bez_nzvu.png
15 years 6 months ago #13475
Replied by nicolas on topic Re: List of categories
You need to go in Display->Content modules and create a new module. There, select category as type of content and a display in list. Then click on apply to save the settings. Then, click on the "joomla module options" button to access the joomla options of the module and set the template position and publish the module and voilà.
15 years 6 months ago #13610
by Nyx
Replied by Nyx on topic Re: List of categories
Thx...yu da best:)
Time to create page: 0.252 seconds
