Listing Products
15 years 6 months ago - 15 years 6 months ago #13668
by cotsios26
Listing Products was created by cotsios26
I am trying to create a restaurant list and I would like it to look like:
<Product title> <characteristics> <price> <Add to cart>
For example:
Chicken kebab__Small $4.00 "Add to cart icon"
_______________Large $8.00 "Add to cart icon"
Is that possible?
Thanks a lot
For example:
Is that possible?
Thanks a lot
Last edit: 15 years 6 months ago by cotsios26.
15 years 6 months ago #13672
Replied by nicolas on topic Re: Listing Products
You can edit the hikashop options of your menu/module and set the layout to "table" and turn on the display of the add to cart button for that. You will find them via the menu Display->Content menus/modules. However, you won't be able to let the user choose the characteristics on the products listing so you will need to separate your variants as normal products. Otherwise, you will get a "choose options" button directing to the product page instead of the add to cart button.
15 years 6 months ago #13718
by cotsios26
Replied by cotsios26 on topic Re: Listing Products
Oh ok now i understand how its working!
On more thing!
How can i add the option for the customer to Add a comment with his order?
On more thing!
15 years 6 months ago #13735
You need to create a new custom field of the table "order" in the menu Display->Custom fields. That is only available in the Business edition of HikaShop.
