Importing Product Variables Using CSV/excel
15 years 7 months ago #13697 by scsplus
I have an excel spread sheet containing 600 plus products the I can import into the shop no problem. Each product has the same variable ie colour. Is there away to add the variable to the excel file. I dont really want to have to add it through the shop one at a time.
15 years 7 months ago #13698 by nicolas
When you say variable, you mean a characteristic ?
If your characteristic is called color and that you have the values blue and red, you can do like this:
product_name,product_parent_id,color
main product,,blue
variant 1,main_product,blue
variant 2,main product,red
15 years 7 months ago #13793 by scsplus
Sorry. Yes its is characteristic. Can these be added to the excel doc or can it only be done once it is converted to csv?
Thanks. This is a great product by the way....
15 years 7 months ago - 15 years 7 months ago #13794 by nicolas
You can of course do the same in excel.
a CSV is only a tabular data set : each comma separates the data into columns and each return carriage separates the data into rows.
so in excel it will be like this:
product_name product_parent_id color main product blue variant 1 main product blue variant 2 main product red
Last edit: 15 years 7 months ago by nicolas.
15 years 7 months ago #13798 by scsplus
Thanks again for amazing support. I take it then each product has to be listed with each of its colur variants. so i need to creat an entry for each color variant. There are 20 different colours so I need 20 different varriaions of that product listed in the excel sheet.
The product id is it ceated automatically or do I need to creat it first before the import?
15 years 7 months ago #13799 by scsplus
15 years 7 months ago #13800 by scsplus
Am I on right track with attached..
15 years 7 months ago #13802 by nicolas
The product id is indeed created automatically
15 years 7 months ago #13803 by scsplus
xml attached
15 years 7 months ago #13805 by nicolas
HikaShop does not handle xml for import, only CSV.
15 years 7 months ago #13806 by scsplus
Sorry saved in wrong format.
15 years 7 months ago #13807 by scsplus
15 years 7 months ago #13809 by nicolas
You don't need to precise all the information in the variants. Only the information which is different from the main product. It's faster and simpler. And when you need to change something in the future, it will be easier as you will only have to change the main product information.
15 years 7 months ago #13858 by scsplus
Thanks again for the corrected csv. When I import my products using this format into the shop I get the following error and the characteristics are not displayed. "6090 products found : 0 new products imported, 5800 invalid product code, 290 already existing products
Have I got the product_parent_id wrong
15 years 7 months ago #13861 by nicolas
Ah, you should specify a product_code in your variants. But please note that each product_code should be unique.
So, if your main product's code is "my_prod", you could have your variants code being "my_prod_blue", "my_prod_red", etc for example.
15 years 7 months ago #13863 by scsplus
great will try that. Thanks
15 years 7 months ago #13864 by scsplus
Hi Changed the code in product parent_id but still get invalid product code error.
15 years 7 months ago #13865 by scsplus
File attached
15 years 7 months ago #13868 by nicolas
The product_parent_id column should contain the code of the main product while the product_code column should contain the code of the variant.
It should be like this:
Parent_Category,categories,product_name,product_parent_id,Confirm Colour,product_code,price_value,images
Base Units,Hi Line Base White,High Line Base 150mm x 720mm,,White,150B,21.71,hlbase.jpg
,,,150B,White,150B_w,21.71,
,,,150B,Cream,150B_c,21.71,
,,,150B,Vanilla,150B_v,23.87,
,,,150B,Alabaster,150B_a,23.87,
,,,150B,Natural Aida Walnut,150B_na,23.87,
,,,150B,Tobacco Aida Walnut,150B_ta,23.87,
,,,150B,Calais Oak,150B_co,23.87,
,,,150B,Light Winchester Oak,150B_lw,23.87,
,,,150B,Lancaster Oak,150B_lo,23.87,
,,,150B,Winchester Oak,150B_wo,23.87,
,,,150B,Canadian Maple,150B_cm,23.87,
,,,150B,Ellmau Beech,150B_eb,23.87,
,,,150B,Sand beige,150B_sb,23.87,
,,,150B,Lissa Oak,150B_lo,23.87,
,,,150B,Light Tiepolo,150B_lt,23.87,
,,,150B,Dark Tiepolo,150B_dt,23.87,
,,,150B,Woodline Mocha,150B_wm,26.33,
,,,150B,Dark Cordoba Olive,150B_dco,26.33,
,,,150B,Ontario Walnut,150B_ow,26.33,
,,,150B,Romano Cherry,150B_rc,26.33,
15 years 7 months ago #13870 by scsplus
Thanks. First class support....
