- Thank you received: 2
Products - Add to Cart button and Formatting
15 years 7 months ago #13950
by momentis
Products - Add to Cart button and Formatting was created by momentis
I have a menu item on my site which links to my store, displaying categories. When a user clicks on the category they want, it brings up a display of products (see attached image).
First - Is there any way to insert an "Add to Cart" button on this list, so the user does not necessarily have to click through to the product?
Second - How can I change the display of this page to add some padding between the products and add rounded-corner boxes to help set off one product from another? I have tried messing with the menu item linking to the category, but that does not seem to carry through to the products. And I have had no luck in trying to figure out CSS changes using Firebug. Believe me - I have tried!!
I think your product is amazing! The one thing I find extremely difficult, even as a LONG time user of Joomla, is the menu and module functions within the app. As a newbie to ecommerce, this may just be the way it usually works. I just have a hard time with it.
Rick
Rick
15 years 7 months ago #13951
by momentis
Replied by momentis on topic Re: Products - Add to Cart button and Formatting
15 years 7 months ago #13962
Replied by nicolas on topic Re: Products - Add to Cart button and Formatting
You need to go in Display->Content modules and edit the associated module to your menu. The module contain all the options of the products listing. You have one option for the add to cart button, you also have one for the background item color and one for rounded corners.
15 years 7 months ago - 15 years 7 months ago #13963
by momentis
Oh, okay. Now I think I am seeing how this all works together!!! I had no idea why my install had all of these "Associated..." modules that were unpublished. Now the lightbulb is starting to brighten!
Thanks, Nicolas!!!
Thanks, Nicolas!!!
Last edit: 15 years 7 months ago by momentis. Reason: Correct word
