Missing cart/currency switcher module
16 years 5 days ago #1452 by zacker
Hi, when i test out hikashop on localhost the shopping cart and currency switch module is auto generated on the left column like this.
But when i try it on a server the two module didn't appear on the web.
Neither can i find it inside hikashop/display/content modules
16 years 5 days ago #1454 by nicolas
You should search for those modules in Extensions->Module manager.
You can always try to install again HikaShop on top of the version you have. You won't loose any data and it might add any missing files or module entry that weren't copied when you move your website.
16 years 5 days ago #1465 by zacker
i tried reinstall but it wont appear
16 years 5 days ago #1471 by nicolas
And do you see the modules in Extensions->Module manager ?
16 years 5 days ago #1474 by zacker
Yes it inside, and it all enabled, i try to play around with it by changing the position like right or top instead of left and save it but it still won't appear.
16 years 5 days ago #1477 by nicolas
I have no idea. Could you try to uninstall those modules and then reinstall HikaShop ? That will reset the options of the modules , and it might make them appear...
16 years 5 days ago #1478 by zacker
yea i tried, nvm i try reinstall everything, thank anyway =)
16 years 4 days ago #1552 by zacker
Hi i think i have some clue, joomla Version 1.5.20 got no problem, but when i test it using latest Version 1.5.22, the module cannot be displayed on the web.
16 years 4 days ago - 16 years 4 days ago #1553 by goldriver
I have exactly the same problem, both modules are present in the extension = modules set to display in position left and are activated and affected to a special menu (page) and when I visit this menu, neither of Hikashop modules appears.
I also just noted that when I access the Hikashop view==module, there is no modules in the window (see below)
Last edit: 16 years 4 days ago by goldriver.
16 years 4 days ago #1554 by zacker
ya agree, but it does shows up on my localhost running joomla 1.5.20, i believe is the version problem
16 years 4 days ago #1555 by goldriver
I'm running J 1.5.21 with the latest Hikashop (12/11/2010) on my dev environment, I have not tried it on any other Joomla version
16 years 4 days ago #1556 by zacker
If you don't mind running on a older version then try 1.5.20 it work, at least solve the problem temporary.
www.joomla.org/announcements/release-new...a-1520-released.html
16 years 4 days ago #1557 by goldriver
Thanks, but since I'm already running another cart program on my live site which is running 1.5.21 I prefer to wait for a fix.
I've been looking actively into this very interesting Hikashop package for about 2 weeks trying to tweek and have it running exactly as I want, I have some spare time to wait for a fix. Also, I'm not sur I will go live with Hikashop until the canadian tax fix is made available.
16 years 4 days ago #1568 by nicolas
I just upgraded our dev website to 1.5.22 and all our modules are still displayed correctly. I couldn't reproduce the problem.
On the right part of the cart module, you should have a link to hikashop options. If you click on it and then save the options, you should now have an entry for the cart module in the listing of content modules. Is that the case ?
16 years 4 days ago #1569 by goldriver
No I Don't have any save options.
Just sent you the site details by email if you want to see it live on the site.
16 years 4 days ago #1584 by zacker
Hi, this is running on joomla 1.5.20 and it working fine.
Notice there is the hikashop option you talking about and the Module Type = mod_hikashop_cart
16 years 4 days ago - 16 years 4 days ago #1585 by zacker
This is running on joomla 1.5.22, without the hikashop option and the Module Type = Hikashop Cart Module.
Maybe you can try downloading a new 1.5.22 package on your localhost and install hikashop see if you face the problem?
So far the problem only occur to me when i use different version of joomla therefore i suggest what maybe the problem.
Last edit: 16 years 4 days ago by zacker.
16 years 4 days ago #1586 by nicolas
The problem is the type which should always be mod_hikashop_cart. It's a problem introduced in the latest version of HikaShop with the new install system. We are looking at fixing the problem and releasing a new version.
16 years 4 days ago #1588 by zacker
ic, thank a lot, will be waiting the new version.
16 years 4 days ago #1592 by johnchr
Create a new Hickashop Cart Module from your admin panel, save it, then edit it and enable it. That works.
