Images: height and width
15 years 4 months ago - 15 years 4 months ago #16132 by Llanut
Hello
I have some problems with images hikashop.
1-How can I do to make thumbnails of each category have different sizes? I want in a category is the width 300px and height 200px. And in the other category is the 300px height and 200px width.
2-How do I get the mini-thumbnails are bigger in product view?
URL1: s358553836.mialojamiento.es/odeclassport...ut=listing&Itemid=13
URl2: s358553836.mialojamiento.es/odeclassport...out=listing&Itemid=8
Last edit: 15 years 4 months ago by Llanut.
15 years 4 months ago #16142 by nicolas
You can use such CSS code :
#hikashop_category_information_menu_ZZZ .hikashop_product_image img {width: XXXpx !important; height: YYYpx !important; }
where XXX and YYY are the width and height desired and ZZZ the id of your menu.
15 years 4 months ago #16159 by Llanut
Replied by Llanut on topic Re: Images: height and width
Ok!Thanks!
I change size wiht diferent category, but my problem still have not solved, because you wanted to delete the space between image and text.
Looking at the picture attached.
I removed the spaces from the red squares, which remains as the green square.
15 years 4 months ago #16160 by nicolas
For the red space, you need that CSS:
#hikashop_category_information_menu_ZZZ .hikashop_product_image{ height: YYYpx !important; }
15 years 4 months ago #16163 by Llanut
I think the problem is not in the picture, could be the size of the cell of the table.
You tell me that I change the image but the problem is that both categories have the same table. I think you need to modify is the cell of the table.
Only when I change this celda resize the image in Configuration> Files: thumbnail height and width of the thumbnail
Thanks for fast replies!!!!!
15 years 4 months ago #16164 by nicolas
There is no cells. The layout is done with divs... The class hikashop_product_image of the CSS I gave you is for the div of "cells" so if you use it you will resize the cell and not the image.
15 years 4 months ago #16166 by Llanut
Yes!
Is possible to modify sizes of div?
What could be the solution?
thanks!
15 years 4 months ago #16167 by nicolas
Yes ! With the CSS I posted before:
15 years 4 months ago #16171 by Llanut
Ougg!!! Sorry! :P
Now is perfect!
But if I want to change div in product view??
Thanks a lot!
15 years 4 months ago #16172 by nicolas
You can modify the sie of the div on the product page with this:
.hikashop_product_main_image_thumb{ height: YYYpx !important; }
but that modifies it for all the products.
The easiest in your case will be to remove the code:
<?php echo $style;?>
from the file "show" of the view "product" via the menu Display->Views. You should have it in two places there.
15 years 4 months ago #16193 by Llanut
Many thanks for your answer! It works perfectly!!
What should be done to change the sizes of a module?
15 years 4 months ago #16198 by nicolas
Could you give more information ?
15 years 4 months ago #16203 by Llanut
I mean,
I've changed the menu _13, with
#hikashop_category_information_menu_ZZZ .hikashop_product_image{ height: YYYpx !important; },
but I have a right module with random products, how I do the same thing I did in the menu, change the size of div?.
Url: Link of problem
15 years 4 months ago #16209 by nicolas
You need to use that in that case:
#hikashop_category_information_module_ZZZ .hikashop_product_image{ height: YYYpx !important; }
where ZZZ is the id of your module.
15 years 4 months ago #16212 by Llanut
Thanks!!!!
Good job!!!!
15 years 4 months ago #17187 by Llanut
I found a problem when you choose different carecteristiques clicker, the images move.
Link of problem
15 years 4 months ago #17200 by nicolas
If you update to the latest version of HikaShop that problem should be solved.
15 years 4 months ago #17252 by Llanut
I updated to 1.5.0 and the problem haven't solved
15 years 4 months ago #17254 by nicolas
If you customized product views in the menu Display->Views, please remove the customization.
15 years 4 months ago #17304 by Llanut
I put CSS in "default", and the problem exist.
Problem
Time to create page: 0.312 seconds
