Does not work with standard SEF?Problem menu links
16 years 3 weeks ago - 16 years 2 weeks ago #163 by Asa
HikaShop does not work with standard SEF?
Last edit: 16 years 2 weeks ago by Asa. Reason: imprecise question
16 years 3 weeks ago #164 by nicolas
It works with standard SEF. We use it on our website and we also use the standard SEF.
16 years 2 weeks ago #166 by Asa
I have a problem :( . I use a local server Server2Go. When I create a menu link on the product category when the SEF, I get no working link. When SEF is off the link works...
16 years 2 weeks ago #167 by nicolas
Your other extensions links work on the front end when you activate the SEF ? If not, it could be that you need to change the name of the htaccess.txt file to .htaccess. It's something related to joomla standard SEF.
16 years 2 weeks ago #168 by Asa
.htaccess - ok. Other extensions links work.
16 years 2 weeks ago #169 by nicolas
So could you copy/paste here the SEFed and non SEFed versions of the links which doesn't work ?
By the way, each time our website sends you an email, we got an automatic response saying to stop spaming:
Прекратите рассылать спам! Немедленно удалите аккаунт связанный с данной почтой. ------------------------------------ Mail.Ru - удобно, доступно, надежно! ------------------------------------
16 years 2 weeks ago - 16 years 2 weeks ago #170 by Asa
Menu HikaShop shows the link: index.php?option=com_hikashop&view=category&layout=listing
Browser link 404:
http://127.0.0.1:4001/index.php?Itemid=65&option=
_____________
possibly at mail.ru again the problem...
never was a spammer :blink:
16 years 2 weeks ago #171 by nicolas
Could you copy/paste the URL of the link BEFORE clicking on it ? ( you can right click on the link and use the "copy link location" option for that ). The link should be SEFed
I tried on my localhost with wamp server 2 and the SEF works properly for hikashop menus. Which option of the SEF of joomla did you activate ? How did you add the HikaShop menu ? You must be missing something somewhere because there is no reason it wouldn't work.
16 years 2 weeks ago - 16 years 2 weeks ago #172 by Asa
Step_1 - OK
image missing http://s40.radikal.ru/i087/1010/70/7a058dc0ceb5t.jpg
Step_2 - OK
image missing http://s56.radikal.ru/i152/1010/f0/9307b6d8a5e5t.jpg
Step_3 - OK
image missing http://s002.radikal.ru/i198/1010/f3/3c14076d222ft.jpg
Step_4 - OK
image missing http://s05.radikal.ru/i178/1010/f3/8f34a433d12et.jpg
Step_5 - Err
image missing http://s58.radikal.ru/i161/1010/81/1bf5d54833d2t.jpg
Right click - copy link:
There is a call to the database id=65, but the link is not taken from the nucleus table...
16 years 2 weeks ago #173 by nicolas
You did it correctly. However, doing the same thing on all websites I tried works properly. Moreover, this link is not correct (that's why it doesn't work when you click on it) but it is generated by Joomla (or whatever SEF component you use ) not HikaShop, so there is not much we can do... I can't ask you an access to your website to try to put traces since you're in local so I'm afraid I can't help you much :/
16 years 2 weeks ago - 16 years 2 weeks ago #209 by Asa
When run the script, somewhere there is a substitution of finished code SEF joomla
<a href="/(alias).html">
on the code HikaShop
<a href="/index.php?Itemid=(ID menu)&option=">
Please, tell me which file (s) responsible for the formation of menu links.
16 years 2 weeks ago #213 by nicolas
We found the problem.
You need to change the declaration fo the function save in the file administrator/components/com_hikashop/classes/menus.php by the code below :
function save(&$element){ $query="SELECT a.id FROM ".hikashop::table('components',false).' AS a WHERE a.option=\''.HIKASHOP_COMPONENT.'\''; $this->database->setQuery($query); $element->componentid = $this->database->loadResult(); if(empty($element->id)){ $element->params['show_page_title']=1; } if(!empty($element->params)&&is_array($element->params)){ $params = ''; foreach($element->params as $k => $v){ $params.=$k.'='.$v."\n"; } $element->params = rtrim($params,"\n"); } $element->id = parent::save($element); return $element->id; }
And then open your menu with HikaShop and save it once. That should fix the problem.
We will release later today a new version of HikaShop with this fix.
16 years 2 weeks ago #217 by Asa
This is great news! Thank you!
Time to create page: 0.938 seconds
