Display problem of products in some modules
15 years 5 months ago - 15 years 5 months ago #17030 by mt_robson
I have a display problem which only occurs in a certain module and all its subcategories:
shop.buch-comptoir.de/index.php/buecher-...glisch--english.html
Here e.g. everything works fine:
shop.buch-comptoir.de/index.php/shop-ueb...ame-broschueren.html
Thx in advance for help, M. :dry:
www.buch-comptoir.de
[Weltweiter Versand seltener Bücher]
Last edit: 15 years 5 months ago by mt_robson. Reason: orthographic errors
15 years 5 months ago #17050 by nicolas
It seems that you have a table layout for your item boxes which shouldn't be possible.
You should check your menu/module's hikashop options and make sure that the item box layout option is not set to table.
15 years 5 months ago #17082 by mt_robson
Nope, this time it didn't work out.
I checked ALL my modules and menus (associated ones, too), all are set to "DIV". Control panel for menu "Bücher nach Sprachen" looks like this:
Hm, pls let me know if and which additional information you need.
Thx in advance, M. :S
15 years 5 months ago #17085 by nicolas
You need to click on OPTIONS_FOR_X. There, change the number of columns to 1 and that should be better.
15 years 5 months ago #17086 by mt_robson
Thx, looks better now for the moment.
Well, I'm done with the setup apparently and can start listing my products.
Thx a lot, Nicolas, for your always incredibly fast and competent help!
Regards, Matt :woohoo:
