Order product list on the frontend- PROBLEM
15 years 5 months ago - 15 years 5 months ago #18001
by gerard_pp
Order product list on the frontend- PROBLEM was created by gerard_pp
I don't know what went wrong here:
can somebody help me?
Last edit: 15 years 5 months ago by gerard_pp. Reason: image removed
15 years 5 months ago #18003
Replied by nicolas on topic Re: Order product list on the frontend- PROBLEM
What code do you have on that line in that file ?
15 years 5 months ago #18005
by gerard_pp
Replied by gerard_pp on topic Re: Order product list on the frontend- PROBLEM
15 years 5 months ago #18006
There is no foreach on that 198 line. Are you sure that you did the screenshot for the correct file ?
15 years 5 months ago #18008
by gerard_pp
15 years 5 months ago #18009
You don't have the code of the latest version so that's why you have that message.
The easiest will be to just change that line to:
foreach(@$product->files as $file){
15 years 5 months ago #18011
by gerard_pp
Looks like it is still messed up
Is the php file on my template's folder the same as the joomla views/orders/tmpl/show.php?
15 years 5 months ago #18012
No.In the latest version of HikaShop, the code is not like that and this error does not appear. You must be using the code from a previous release.
15 years 5 months ago #18014
by gerard_pp
I recently updated to hikashop 1.5.1 Looks like the code is messed... Can you please send me the updated code to replace what i have on my template's folder?
15 years 5 months ago #18015
Just click on the "remove customization" icon on the views listing for that view and you will use automatically the new version.
15 years 5 months ago #18018
by gerard_pp
:laugh:
I was surprised on how easy this error got fixed. If i knew from the beginning it was so easy, i wouldn't bother you.
Thanks again bro.
Thanks again bro.
