One Product Per Module?
15 years 5 months ago #18552
by DelcoCS
One Product Per Module? was created by DelcoCS
I am trying to add one product per module. I see that I can rotate products within a module, but that won't work for me, I have to have one product displayed at all times in the same module and have multiple modules across my site with one product in each.
15 years 5 months ago #18559
Replied by nicolas on topic Re: One Product Per Module?
Create one unpublished category for each product you want to display like this. Then, attached that category as a second category of your products and then use these categories as parent category in your modules. Since you will have only one product in the category, the module will display only one product.
15 years 5 months ago - 15 years 5 months ago #18571
by DelcoCS
Replied by DelcoCS on topic Re: One Product Per Module?
How do I add an add to cart button into the module? Sorry, I'm really new to this.
nvm, figure it out, lol thank you for the help
Last edit: 15 years 5 months ago by DelcoCS.
15 years 5 months ago #18573
When you edit a product, you can see all the categories to which the product is attached on the right part of the screen. You can add new categories there.
