**SOLVED**Hikashop/Joomla 1.6 titles problem
15 years 5 months ago - 15 years 4 months ago #18715 by skatercorpse
First of all...Hikashop is great! Is enough to try out the options here and there and you can easly set up a shop!
Documentation is really helpfull and complete. Thanks to the forum other problems can be easly solved.
And the fact that you can use it also just as a catalog component make it even greater.
Not to mention that there is the free version!! :)
Really, thank you for this component!
Anyway...I have a problem with the titles. :P
I would like that a title is shown when I am in the front-end shop page(I used the category listing in my case).
I checked the option to show the title in the Joomla menu's options.
I tried to check "yes" and "no" in the Hikashop menu's options to see if anything changes ("Use menu name instead of category name for title"..I read other topics in the forum regarding to it...).
But the title never shows.
Weird thing is when the cart is empty and I click on the cart icon I get the message "Your cart is empty" and below there is a title "Product category".
When I add an item to the cart and then I delete it, I get the message "The cart is empty" and the title I set in Joomla menu's options ("Shop Angolo creativo" in my case) is displayed.
Any idea how to solve this?
ps:
In the CSS there is also a small error I think.
div.hikashop_user_regsitration_page
I think it should be div.hikashop_user_regIStration_page
Last edit: 15 years 4 months ago by skatercorpse.
15 years 5 months ago #18727 by nicolas
There was a problem with listing titles on previous versions of HikaShop. If you don't use the latest version, please update and try again to activate the title in your menu.
PS: Thanks, we'll change that for next release.
15 years 5 months ago #18734 by skatercorpse
Unfortunately I am using the latest verstion 1.5.1.... :(
15 years 5 months ago #18740 by nicolas
Could you give a link to your page ?
15 years 5 months ago #18982 by skatercorpse
Here I am!
Ok, website uploaded!
Here you can check it: www.angolocreativo.ch
15 years 5 months ago #18994 by nicolas
Could you do a screenshot of your shop menu options with the show title option activated ?
15 years 4 months ago #19242 by skatercorpse
Here you have the screenshots
15 years 4 months ago - 15 years 4 months ago #19243 by skatercorpse
15 years 4 months ago #19244 by skatercorpse
15 years 4 months ago #19251 by nicolas
Could you try to redownload and reinstall hikashop on your website just in case...You options are fine and it works with the same settings on our end...
15 years 4 months ago #19257 by skatercorpse
ok, I've just done it but it still doesn't work... :(
15 years 4 months ago #19275 by nicolas
Could you provide a back end access to your website so that we can check out the settings and try to find a solution ?
15 years 4 months ago #19373 by skatercorpse
Ok, I've just sent the data for the back end access.
Hope you can find a solution.
Thank you! ;)
15 years 4 months ago #19417 by nicolas
It's fixed. It was a problem in the code. It will also be added in next version of HikaShop.
15 years 4 months ago #19493 by skatercorpse
Perfect!
Thank you Nicolas!
When do you think a next version will be released?
It would be good if you can write what you had to do to solve the problem so other users can fix the problem themselves if they need (if it is not too much work or if soon a new released will be available).
Another question...what about when I click the cart icon when is empty? Is it right that it also shows the "Product category" title? I mean, why not showing anything at all or better the main shop page?
PS: did you notice my website loading slow? Because it seems to me that is really slow...just to have a confirmation from someone not living near to me...
Thank you!
15 years 4 months ago #19494 by nicolas
Next version will be released this week.
The solution was easy. I edited the file listing of the view category via the menu Display->Views and change the line:
$title = 'show_page_title';
if(version_compare(JVERSION,'1.6','<')){
}else{
$title = 'menu_text';
By default, when the cart is empty and that you click on the cart link, it redirects you to the listing of products of the main category. If you want it to go somewhere else, you can just enter the URL in the option "URL where to redirect when the cart is empty" in the tab Checkout of the config.
I didn't notice that your website was slow.
