Problem with Shopping Cart
15 years 4 months ago #19578 by mohairbears
Hi, I have a problem with my shopping cart, when different sizes etc of the same product are selected the code replicates itself?
e.g. Plastic Joints: Plastic Joints:Plastic Joints: 25mm
This is ok at checkout though?
15 years 4 months ago #19592 by nicolas
It's a bug we found out yesterday. We fixed it on our end and it will be available in next release tomorrow.
If you want to fix it, you need to edit the file administrator/components/com_hikashop/classes/product.php and add at the beginning of the function checkVariant the line:
if(!empty($variant->variant_checked)) return true;
and at the end of the function the line:
$variant->variant_checked = true;
Time to create page: 0.039 seconds
